trailer wiring
Old Oct 1, 2009 | 04:40 PM
raydar's Avatar
raydar
trailer wiring
I have a 99 ranger the trailer wiring that was on it was not working right. I was going to follow the wiring but gave after following it for awile looked like it went all the way up to the front. I just cut it off and taped it up. Here is the problem i bought a wiring kit for it and when I hooked it up I have no turn or brake lights on the truck or plug in. I thought maybe bad kit bought anouther one same thing (when i take it out lights on truck work fine). anyone have idea what it could be
Old Oct 1, 2009 | 07:01 PM
87 XLT's Avatar
87 XLT
If I had a 99 Ranger I would also have the factory wiring diagrams for it & could tell you for sure.
My guess is that you need to install a "trailer tow left turn & stop relay" & a "trailer tow right turn & stop relay." And also make sure the fuse for these relays is not blown.
Remove the lid from the fuse/relay box under the hood & flip it over. Is there a diagram showing which fuses/relays do what?
Old Oct 1, 2009 | 07:52 PM
g_k50's Avatar
g_k50
The fuse in the fuse box is number 35, a 15amp mini fuse. It needs a relay also.
The fuse for the turn signals should be in and working.
The wire for the trailer DG is the right turn YE is the left turn BN/WH is the running lamps.
WH is the ground
These wires all run into a C418 Connector,
It's called Trailer Tow Connector, Trailer/Camper Adapter.
Old Oct 1, 2009 | 08:23 PM
raydar's Avatar
raydar
i looked at it and all it says is relay number 1,2,3, etc
Old Oct 1, 2009 | 08:52 PM
raydar's Avatar
raydar
WH is the ground
35 is a dead slot in my truck
Old Oct 1, 2009 | 10:59 PM
g_k50's Avatar
g_k50
I think you are breaking the electrical path to ground when you install the trailer kit.
Do you have the orginal truck wires that went to the trailer tow connector? Should be a white, BN is brown I think BN/WH is brown with a white stripe, YE is yellow, DG is dark green. White was the ground runs to the fuel tank.
Old Oct 1, 2009 | 11:01 PM
g_k50's Avatar
g_k50
Relay should be in slot 13
Called Park Lamp/Trailer
Old Oct 1, 2009 | 11:11 PM
g_k50's Avatar
g_k50
There's a connection that connects the tail lights to the wire bundle that runs to the front of the truck. The Trailer Tow Connector wire bundle runs in to the main wire bundle above or in front of this connector, find the old wires and splice into them.
cdrmotorsports
Sep 8, 2010 04:11 PM
bendereric
Mar 31, 2010 07:56 PM
ted368
Jun 4, 2009 07:24 AM
jjbigwheel
All Things Towing
Sep 28, 2006 08:16 PM
