Aerostar Ford Aerostar
Sliding door latch
Old Oct 1, 2009 | 02:22 PM
whatstar1117's Avatar
whatstar1117
Sliding door latch
Today the sliding door on my Aero began making a cracking noise as latch was opened. I think its the upper jaw on latch assembly snapping open. Lubrication made no difference. I can created a bit of lateral play at latch point when door is closed but door stays closed. Any ideas?
Old Oct 1, 2009 | 03:34 PM
Pablo-UA's Avatar
Pablo-UA
bad bearing.... time to change some parts.....
Old Oct 1, 2009 | 07:16 PM
93nighthawk's Avatar
93nighthawk
I have never heard of the latch going out before. Have you checked the condition of your striker Bolt? There is a plastic bushing on there that tends to wear out over time. A replacement can be found at any auto parts store.
Another part that could be causing your issue is your lower roller. Very common wear part.
(pics courtesy of Asavage)
That is what my bottom roller looked like. Once I replaced it the door opened and closed a heck of alot better.
Old Oct 2, 2009 | 10:23 AM
KhanTyranitar's Avatar
KhanTyranitar
A agree, the lower roller can cause all sorts of issues with the latch by putting additional strain on the parts. If ignored, it can break stuff. All of our Aeros have had the lower roller replaced. It is a wear item. Keeping the lower track clean helps it last longer. Great pics there nighthawk, that really does show the difference between old and new. When it wears out, the whole door sits 1/4" too low, which prevents the latch from lining up properly.
Old Oct 2, 2009 | 10:33 AM
mmxchamp's Avatar
mmxchamp
Where did you get the lower roller from? I have been considering finding as nice of one as I can at a junkyard because I couldn't find one online.
Old Oct 2, 2009 | 01:43 PM
96_4wdr's Avatar
96_4wdr
might try one of our site sponsors
www.partsguyed.com
Old Oct 3, 2009 | 03:00 PM
whatstar1117
I'm going to try striker bolt cover and lower roller(well worn by the way) but I can duplicate the noise by loading latch jaws against spring tension with a finger and releasing. It seems to be generated by jaws against latch case or against something internal. Probably much ado bout nothing.
Old Dec 13, 2009 | 03:42 PM
whatstar1117
Finally got around to replacing missing sleeve on sliding door strike bolt. It cured "cracking" noise when latch was opened. Roller replacement next.
Old Dec 28, 2009 | 06:14 PM
tp4pdb's Avatar
tp4pdb
I had the same problem with my '93 Aero. I replaced both the striker bushing and the roller with parts ordered through the local Ford dealer. Getting the old roller off of the bracket was a nightmare but the job got done and the problem is solved. No more cracking and dragging, at least when operating the sliding door.
Old Dec 30, 2009 | 07:59 PM
whatstar1117
I'll give my local Ford dealer a try on rollers. I replaced mine with marginally better ones from junk yard. Still needs more vertical lift to get alignment correct.
Old Dec 30, 2009 | 09:01 PM
99f350sd's Avatar
99f350sd
I have the perfect bearing for the slider bottom roller that wears out..
1614-ZZ New 3/8" Quality Single Row Bearings-1614Z - eBay (item 370131908700 end time Jan-10-10 18:03:11 PST)
Its the perfect replacement. A little higher and it should never wear out. Smooth as glass.
Did all my vans..I think I locktited it to the shaft..can't remember.
Dick
http://cgi.ebay.com/ws/eBayISAPI.dll...IBSA%3AMT%3A11
Old Jan 1, 2010 | 04:14 PM
whatstar1117
I ordered bearing suggested by 99f350sd for lower roller on side door. For the money....... then I got to thinking that the factory roller may be a sacrificial wear item. Either the roller wears or the track wears. I'm sure the metal in a roller bearing is a lot harder than the track material. Think this is a problem?
Old Jan 1, 2010 | 04:35 PM
xlt4wd90's Avatar
xlt4wd90
That would certainly make sense. How does your track look now, with the roller worn out? The part of the bearing that would ride on the track is the outer housing, which is probably not nearly as hard as the journals, but still harder than the plastic roller. You don't want it to act like a pizza cutter. Of course, you can weigh that against how long you plan to keep the van.
Old Jan 1, 2010 | 08:19 PM
99f350sd's Avatar
99f350sd
Its a wider bearing and it rolls. I don't think anything is going to wear.. Not in this lifetime.
Don't forget the old bearings have grooves in them when the plastic wears off and when it doesn't spin its grinds the floor..
Old Jan 2, 2010 | 04:18 PM
whatstar1117
Original roller had not quite worn through; junk yard replacement slightly better so track looks good. My Aero is used as a work van; lots of saw dust and drywall dust. I blow out track/step area weekly; lube monthly.
How long do I keep the van? Til some auto maker offers a suitable replacement. Sprinter too big for city parking; Transit Connect is too short and can't tow my 3500 lb hauling trailer.
Back to the subject at hand, I'll give the bearing a try and keep an eye on it. It may not have enough traction to roll through the dust/crud but the price is right.
