Cuts out when driving
Old Oct 1, 2009 | 09:56 AM
BAZOOKA FACE's Avatar
BAZOOKA FACE
Have a 88 f350 that will run perfect on front tank until driving long enough to use 3/4 of the tank then will start to act like its running out of gas. When switched over to rear tank will run fine. After letting sit for awile will run if switched back to front tank. All filters,fuel pumps, coil, ignition module, and rebuilt distributor. Any ideas?
Old Oct 1, 2009 | 10:14 AM
Conanski's Avatar
Conanski
Sounds like the pump is failing.
Old Oct 1, 2009 | 11:05 AM
BAZOOKA FACE
Just replaced the pump in front tank again last week. Still the same concern.
Old Oct 1, 2009 | 02:13 PM
Silverback86's Avatar
Silverback86
When's the last time you've changed the fuel filter? have you checked the strainer? If something is partially clogged it makes sense for the pressure of a full tank to assist in forcing the fuel through, and when the pressure's reduced it can't supply the fuel at the pressure it needs to. It does sounds like a pressure loss along the way, which is what I think Conanski was going for.
Old Oct 2, 2009 | 09:33 AM
BAZOOKA FACE
Fuel filters where replace with pumps. what strainer?
Old Oct 2, 2009 | 10:08 AM
Silverback86
Sorry, the strainer is on the pump in your model. My apologies. Can you run the truck on the front tank and take a fuel pressure reading and let us know what you get?
Old Oct 2, 2009 | 06:55 PM
BAZOOKA FACE
fuel pressure is good when running good. had ford dealer check pressure. maybe could leave pressure guage on truck and drive until it acts up?
Old Oct 2, 2009 | 07:02 PM
Silverback86
You could... but let's think outside the box here...
1. did you replace the fuel pump relays when you replaced the fuel pump?
2. what about the lift pump (they still have those with dual tanks I believe)?
If either of those is acting up it makes sense, those relays are mechanical and have very finite lifetimes...I'd check and try to find any bare/damaged wires to any of the fuel system pumps and relays.
brucers
Aug 26, 2011 07:03 PM
J and J
Apr 28, 2011 05:29 PM
KSTTAC
Apr 1, 2007 07:27 PM
Saintelias
Sep 3, 2004 09:34 PM
scott94f150
Mar 31, 2001 07:33 PM
