Replacement Hinges?
Oct 1, 2009 | 08:34 AM
Replacement Hinges?
Should I replace my worn out Door Hinges with an after market Hinge? Noticed they are $50.00 a piece Cheaper buying them this way....Any suggestions?
Oct 1, 2009 | 08:53 AM
just replace the pins and bushings.
any parts store should have the replacements.
removing the hinges is a hassle.
Oct 1, 2009 | 08:57 AM
Ok thanks for the Input.......whats involved with replacing Pins and Bushings on a 1995 F-150 4x4 Truck?
Oct 1, 2009 | 09:52 AM
Oct 4, 2009 | 07:23 PM
Quicklook2........your Advise worked like a charm.........Had both replaced in less then an hour..
Thanks for great Advise...
Oct 4, 2009 | 10:16 PM
glad it worked out for you.
that was a lot easier then taking out the hinges.
Jul 6, 2010 | 10:22 AM
Thank you for taking the time to put the link up. The pictures helped me alot!! Thanks, Keystonepaul
Aug 26, 2010 | 11:24 AM
This is vary helpful, thank you
Aug 26, 2010 | 12:30 PM
glad it helped so many out.
Aug 26, 2010 | 01:41 PM
just what I've been looking for. The drivers door on my truck is starting to act up.
