Replacement Hinges?
Old Oct 1, 2009 | 08:34 AM
BarkinSpyd3rs's Avatar
BarkinSpyd3rs
Replacement Hinges?
Should I replace my worn out Door Hinges with an after market Hinge? Noticed they are $50.00 a piece Cheaper buying them this way....Any suggestions?
Old Oct 1, 2009 | 08:53 AM
quicklook2's Avatar
quicklook2
just replace the pins and bushings.
any parts store should have the replacements.
removing the hinges is a hassle.
Old Oct 1, 2009 | 08:57 AM
BarkinSpyd3rs
Ok thanks for the Input.......whats involved with replacing Pins and Bushings on a 1995 F-150 4x4 Truck?
Old Oct 1, 2009 | 09:52 AM
quicklook2's Avatar
quicklook2
real easy.
dremel cut the center and pry out what is left.
i will see if i have a link for pics of how to do it when i get a chance.
this is a link for a lincoln town car but it is exactly the same for f150.
http://www.lincolnsonline.com/tech/00045.html
also look here for the pin info for f150.
http://www.google.com/search?hl=en&c...&aq=f&oq=&aqi=
google is your friend.
Old Oct 4, 2009 | 07:23 PM
BarkinSpyd3rs
Quicklook2........your Advise worked like a charm.........Had both replaced in less then an hour..
Thanks for great Advise...
Old Oct 4, 2009 | 10:16 PM
quicklook2's Avatar
quicklook2
glad it worked out for you.
that was a lot easier then taking out the hinges.
Old Jul 6, 2010 | 10:22 AM
Keystonepaul's Avatar
Keystonepaul
Thank you for taking the time to put the link up. The pictures helped me alot!! Thanks, Keystonepaul
Old Aug 26, 2010 | 11:24 AM
snowpig32's Avatar
snowpig32
This is vary helpful, thank you
Old Aug 26, 2010 | 12:30 PM
quicklook2's Avatar
quicklook2
glad it helped so many out.
Old Aug 26, 2010 | 01:41 PM
pnp522's Avatar
pnp522
just what I've been looking for. The drivers door on my truck is starting to act up.
