another E4oD problem
Old Oct 1, 2009 | 06:30 AM
tbart16's Avatar
tbart16
A buddy of mine was using my truck(95 dually) yesterday he was towing a skid steer about 10k lbs. When he lost all forward gears truck has reverse ,but it does'nt even try to move forward. The tranny temp was normal and their were no signs that the tranny was on its way out. Could it be something electronic or is it the end of the road for my E4oD
Old Oct 1, 2009 | 07:14 AM
Brown Falcon's Avatar
Brown Falcon
RAB Sensor... on top of the rear diff, pull it out and clean it off with a clean rag or try a new one. Also the range selector on the driver side of the transmission could have gone out.
Also is the OD light blinking on and off?
Old Oct 1, 2009 | 08:58 AM
tbart16's Avatar
tbart16
I will check the OD light I have'nt seen the truck yet it was towed to a garage last night What is an RAB sensor and what does the range selectot look like Thanks
Old Oct 1, 2009 | 09:05 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It isn't a sensor. There is NO sensor that will make the trans lose forward gears. The only way it can lose forward gears is when something mechanical in the trans breaks. This trans is coming out and getting rebuilt or replaced.
Old Oct 1, 2009 | 09:17 AM
tbart16's Avatar
tbart16
thanks Mark I was kinda thinkin that was the case ,but I just wanted to check here on the forum first thank you again
Old Oct 1, 2009 | 12:04 PM
redone1's Avatar
redone1
That sucks. Let us know what failed. I'm curious.
Old Oct 1, 2009 | 12:42 PM
tbart16's Avatar
tbart16
i will keep everyone posted
