map sensor line
Old Oct 1, 2009 | 04:31 AM
ChunderDownUnder's Avatar
ChunderDownUnder
map sensor line
Howdy bro's and bro ettes
I need to replace my map sensor line . Im doing the AIH delete with Clay's plug and I have my boost gauge T'd in the map line. Can I use some heater hose ? and does anyone know what size hose it is. ?? Thanks in advance.
Old Oct 1, 2009 | 07:44 AM
mueckster's Avatar
mueckster
1/4" fuel hose will work just fine. I've had that on mine for several years now.
Old Oct 2, 2009 | 02:45 AM
ChunderDownUnder
Thanks Roland
Old Oct 2, 2009 | 06:53 AM
ltl_jrw's Avatar
ltl_jrw
What is this you are talking about?
Old Oct 2, 2009 | 09:14 AM
mueckster's Avatar
mueckster
The rubber hose going from the intake spider to the MAP sensor.
Old Oct 2, 2009 | 03:18 PM
ChunderDownUnder
See the T piece to the left of the spider. Thats my boost gauge which is tapped into the Map sensor line.
Now the AIH delete is removal of the plug you can see that goes into the left tube of the spider, just to the right of the T. with the wire attached to it. You put one of these cool lookn plugs from Clay
Riffraff Diesel: RDP AIH Tapped Fitting
and you are good go. It is threaded so you can instal your boost gauge there. It removes some restriction from the internal of the spider and one less cable. But more importantly - it looks good
PRIMERED79 SHORT BED
Dec 23, 2016 05:48 PM
Jmanb13
Sep 19, 2015 07:48 PM
tommyl
Sep 1, 2014 10:00 PM
1L243
Apr 1, 2011 08:33 PM
kirbykoon
Oct 14, 2010 05:23 PM
