Still Rough Idle?
Old Sep 30, 2009 | 08:14 PM
2 stroke man's Avatar
2 stroke man
Still Rough Idle?
man, i can't get this whipped! i am still getting a rough idle at times. no matter the chip setting, even with new Fuel Filter, cleaned FPR screen, and all that. what do i check now? its also a little choppy when revving it up and holding it a little high RPMs to jump start someone. i just can't figure it out. Ideas?
Old Sep 30, 2009 | 10:00 PM
95bigtime's Avatar
95bigtime
I have that also-pulled codes and keep getting IDM fault. Buzz test and it fails every time, contribution test passes so I ordered IDM. Do you have access to scanner?
Old Sep 30, 2009 | 10:10 PM
cowmilker08's Avatar
cowmilker08
Have you tried unplugging the ICP when it is running rough? If the idle smooths out when you unplug it then the ICP is bad.
Old Oct 2, 2009 | 06:06 AM
2 stroke man
ICP is good. i will try to get it to a good scanner, not one of the auto parts ones. i need to check into it when i get back home. DOwn in TN getting my new skidsteer this morning.
02Gator
Sep 30, 2012 10:41 PM
Brown Falcon
35
Jun 2, 2010 11:56 AM
gfsdude
3.0L V6
Mar 31, 2009 03:39 PM
Sam_Fear
Jun 13, 2006 02:07 PM
Charnsen
1983 - 2012 Ranger & B-Series
15
Jan 6, 2003 09:01 AM
