6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Tire press. sensor
Old Sep 29, 2009 | 05:37 PM
HH60FE's Avatar
HH60FE
Tire press. sensor
Need a little help for a friend. He's got an 08 V10 and want's to downgrade to 17 in. rims. What will he need to do for the tire pressure sensor light to stay off if running these rims? Use a piece of tape to cover the light (thats what I told him). He mostly want's to run winter tires on these rims then go back to his summer tires on 18s and was wondering if this will throw any codes.
Thanks much.
Old Sep 30, 2009 | 06:28 AM
Reave1's Avatar
Reave1
Only way to eliminate the light is to add sensors to the wheels. The system is designed to not be able to be turned off. So new sensors on second set of wheels or tape. Good Luck
Old Sep 30, 2009 | 09:06 AM
HH60FE's Avatar
HH60FE
thought so. thanks.
Old Sep 30, 2009 | 02:52 PM
smotrs's Avatar
smotrs
Just make sure that the tires are rated for what the driver side door sticker says, otherwise adding the sensors will just be a waste of money.
chadillac80
Jan 12, 2014 04:57 PM
Vaccuum
Nov 18, 2010 11:54 PM
F350mikey
Aug 23, 2010 03:58 PM
turbostroke
2004 - 2008 F150
56
Oct 15, 2007 09:24 AM
