Easiest place to tap into turn signals?
Tilt the steering column down to give yourself more room to remove the top cover. Up for the bottom.
I recalled I had to detach the dashboard front cover to really get it out in order to replace the turn signal lever (multi-function switch). There are 2 screws under the top side of the radio opening. You'll need to pull the radio out to do this. Then just pull the cover towards you as it unsnaps.
I would disconnect the ground off the battery when doing this. You don't want to have that airbag pop by accident while you're tinkering down there.
on
You should be able to pop the covers without the extra work of the dash. Just don't forget to unscrew the tilt lever also.
I also put the key cylinder back in while doing the work to get away from the ding, or unplug your battery, but you may want power to sort out your left/right turn signal wires.
andrew871
1997-2006 Expedition & Navigator
25
07-26-2017 02:46 PM
4x4pwr
1999 to 2016 Super Duty
10-22-2016 05:25 PM
dannyboy11222
19
01-27-2016 06:27 PM
