285/75/18 MT/R on Stock F250?
I was told by the tire warehouse shop here in VT that size will fit my 2008 SD 250 no problem, they are a plus 1 size over the stock tires on it now they tell me, no issues BUT I was worried with my Vbar chains would they become an issue as they couldnt get me studded tires in 18 inch.
No answer for me on chains with the plus 1 tire voer my stock ones, so I went with 275/70/18 which is what came on truck and manual says chains no problem.
if you run V bar chains and get those tires let me know how they clear please!
edit: oh yes, I never did find out if they are a E range tire in that size, do you know? thanks
I plugged in the metric tire sizes into that online calculator and here's what I got:
LT275/70/18
33.1" Tall
10.8" Wide
LT285/75/18
34.8" Tall
11.2" Wide
Judging by the available space in the fenders, it looks like they'll fit my truck. I do use my truck off road from time to time, and I want to make sure there is adequate clearence for the suspension to fully articulate.
LT275/70/18
33.1" Tall
10.8" Wide
LT285/75/18
34.8" Tall
11.2" Wide
I would think those tires should fit OK,,I almost purchased that size tire in the BFG AT design,,for my 06' F-350,,,,big $$$,,instead I purchased a set of 07' F-250 stock Alloy take-off wheels,,, like a week old,,brand new condition (f-250 have the same brakes) and the 17" wheels fit fine,,,,purchased a set of 285/70/R17 Hankook Dyna Pro MT tires,,had them studded as well,,,what great traction these tires are, for mud/ snow,,,whatever,,,some road noise,,but now I have a winter set,,and summer set of wheels and tires.
PS,,The Hankook's are D rated tires,,,at a like 3196 lb rating per tire,,compared to the Contis E's at 3650 (approx) per tire,,,my truck is about 7900 lbs with the cap, and tools that I normally carry,,,,then add the 900 lb 9' Fisher plow,,,,,the tires have done great last 2 years.
They Fit Easily
I test fit the LT285/75/R18 Goodyear Wrangler MT/R on my 2009 F250, and they fit no problem at all. They are a full 35" tall. As a few others have said, a 35x12.50" tire can fit under these trucks with no lift.
So far, I've flexed it out and hit bumps turning, and there is no rubbing at all. Here are a few pics that will have to tide you over until I can get the truck all washed up and get better lighting conditions.
Asldo got the windows tinted. 35%
