emergency brake
Old Sep 28, 2009 | 06:02 PM
lee231's Avatar
lee231
emergency brake
My emergency brake pedal goes all the way to the floor, I think it's needs to be replaced. Does anyone have any tips for the job? TIA Lee
Old Sep 28, 2009 | 07:42 PM
HH60FE's Avatar
HH60FE
Do you use it all the time, if so, maybe the cable just needs adjustment, but here's a bump
Old Sep 28, 2009 | 08:44 PM
lee231's Avatar
lee231
Had a new cable, last year. I think the pedal has a automatic slack adjuster incorpated into it and that may be worn out or broke. There is a recall on the cable and controller, (#17124) for the manual transmissions, just haven't found out if my trk is included or may have already been done before I got it. Lee
Old Sep 29, 2009 | 08:57 AM
DISLFVR's Avatar
DISLFVR
Locomotive breath
What year is your truck? Most have to be manually adjusted, the e-brake drums have slots near the bottom for this.
Old Sep 29, 2009 | 02:57 PM
big poppa's Avatar
big poppa
If its broke, check this out NEW OEM FORD F250 F350 E BRAKE CABLE :eBay Motors (item 370264953730 end time Oct-01-09 07:20:09 PDT)
Old Dec 18, 2009 | 06:19 PM
rmwitt's Avatar
rmwitt
i had the same problem this morning. the brake pedal would not release; pushed on it, pulled the release lever; pushed on it, pulled the lever. Finally the pedal was to the floor, and really stuck. The truck would not move (from the middle of the street). We tinkered (poked around) with the mechanism, and the brake line finally released, but the pedal is still stuck on the floor, and of course the red brake light appears in the dash panel display. At least, i can move the truck out of the middle of the street.
Does any one have some suggestions?
Tony Lee
Oct 2, 2014 08:08 PM
macksarf
May 30, 2006 03:49 PM
areostar_ca
Aerostar
Apr 10, 2006 09:57 PM
jowilker
Dec 18, 2001 06:13 PM
ace8077
1997 - 2003 F150
Apr 21, 2001 05:12 AM
