390 block build suggestions
I would like to put a mediam cam, 4 barrel carb and possibly electronic ignition in it. I am also thinking about headers. I was wondering if i should leave the block as a 390 or go bigger, also what specs and numbers should i go for for bore, stroke, and all that...
Any and all suggestions would be appreciated, the rebuild is still a couple months off, but I am planning and researching now.
Thanks
The 360/390 block has a 4.05 bore. You can't overbore them enough to make a meaningful CID difference, but you can get an aftermarket stroker out to about 445 cubes.
Check the FAQ at the top of this forum. There are also many build threads here.
The basic formula is just what you said, including headers. Head work or aftermarket heads if you are going for bigger power.
Budget?
headers will definitaly be in order. What stroke kit would be best?
I don't know a ton about enginge rebuild, i was planning on doing the engine after we study engines in my Diesel Tech program. Hopefully after then i will know more, but i am doing research now.
Amazon.com: How To Rebuild BIG-BLOCK FORD ENGINES (9780895860705): Steve Christ: Books
Gonna be tough to do any stroker job on your budget:
Flatlander Racing - Ford Stroker Kits
A 428 crank will give you 410-418 with the 390 bore. Finding one, and pistons, will be a challenge.
Anyway, review the suggestions and other builds and plan accordingly.
All in all what i am looking for is basically a good stout running FE and i have the 390 to work with. I would be happy with a reliable engine, that was capable of pulling around 5000 lbs without complaining too much.
Maybe 4 bbl carb and headers, and a real good tune up would be a great place to start.....
I have not read the book, but all books of that type cover piston/valve clearance for HP builds.
Decent compression, RV cam, good manifold (check this forum for manifold threads, lots of examples given) 650 cfm 4bbl, headers--you'll be able to pull 5000 lbs straight up a wall if you want.
