just died
Old Sep 29, 2009 | 08:38 PM
silverstang's Avatar
silverstang
I don't recommend leaving the IPR hooked up more than 1 minute. And yes, a competant diesel technician will be able to tell the difference between a high pressure pump and an IPR valve. You might have a high pressure oil leak causing this issue as said before. Might need a new STC fitting. There is no oil leaking on the back of the engine/top of the trans is there? I've seen some stc fittings bust the rear cover above the trans/passenger side. (its not likely but have seen it before). What year model truck is it? A high pressure pump failure is not all that common on the new build 6.0 diesels with the newer pumps.
krewat
Modular V10 (6.8l)
Mar 13, 2021 04:39 PM
Vince79vette
Nov 14, 2013 11:37 AM
Roasted7
Aug 15, 2013 03:14 AM
Stewart_H
Feb 1, 2012 11:52 PM
trencherman
Jul 1, 2006 08:12 AM
