Wiper problem
Old Sep 29, 2009 | 11:31 AM
BKS72's Avatar
BKS72
Wish I would have read this last week - I'm going through the truck I just got going and fixing all the small annoyances and this wiper problem is one. I had the e brake pedal out last week putting in a new cable.
Can I just resolder those broken connections if that turns out to be the issue with my module or do the bad solder joints lead to other damage on the board? I know this sounds incredibly cheap, but the only JY close to the house is about as overgrown as any I've seen. The less I wade the weeds there the happier I am
Old Sep 29, 2009 | 06:05 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You can resolder them, As I said it didn't last long for me.
But I haven't had a problem since I put in the new one and just left it ziptied up there behind the fuse box.
Maybe it is because it doesn't get the vibration.
Old Sep 30, 2009 | 07:03 PM
CK3's Avatar
CK3
Thanks for the info guys.. I'm gonna pull it out & see if I can solder it up..
Old Jan 31, 2010 | 12:51 AM
AppleValleyDieselguy's Avatar
I've recently had the same issues; wipers only working on high and would finally stop after a few minutes. I replaced the switch but there was no change. After perusing this thread, I decided to have a look at the relay or governor which is mounted directly behind the headlight switch and right on the parking brake bracket. Every time the parking brake is released, the relay receives a hell of a blow. After disassembly, I discovered a crack in one of the solder joints in the relay. A quick fix and everything is working fine now. BTW: my dealership wanted $199.00 for a new governor. Must be made of gold nowadays!
Old Jan 31, 2010 | 08:18 PM
Alvin in AZ's Avatar
Alvin in AZ
Glad to hear it worked for you. :)
Alvin in AZ
Old Jun 12, 2010 | 07:08 PM
Roader's Avatar
Roader
Two open solder joints
The diode and a resistor had cracked joints. I reflowed all the joints and tie-wrapped the module out of the way. I got intermittent wipers again! Mine had a phillips head screw holding module bracket to the dash. A stubby screwdriver works best.
Old Jun 12, 2010 | 07:29 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Welcome to the forum Roader!
Glad you got it fixed.
Old Jun 12, 2010 | 08:18 PM
Roader's Avatar
Roader
Thank you, Jim!
The posts and the people on this forum have been SO much help. I'd be stuck without it.
Old Sep 26, 2011 | 07:45 AM
UncleRock's Avatar
UncleRock
Have an extra multi switch in the van will check other things.
They go on but wont turn off from the intermittent
they also don always return to park position
Old Jan 12, 2014 | 03:28 PM
TPurdy's Avatar
TPurdy
Wiper Module
It has taken me a while but I want to thank ya'll for the help on my wiper module. I re-solder it once and it worked, sort of. Being the stubborn sob that I am I took it out and soldered it again. The second time I found broken solder joints under the relay. It has been working for 3 years now. If you have something broken, try to fix it, you have nothing to loose.
Old Oct 31, 2014 | 03:31 PM
Grems4ever's Avatar
Grems4ever
Woo Hoo! i think I finally figured out what's going on with my wipers. Now I just need to pull it out and start scrounging the junkyards...
Thanks Everyone.
phoneman91
64
Feb 2, 2025 05:40 PM
zippi
1947 and Older Ford Trucks
Jun 10, 2017 04:28 PM
Jesser02EX
Aug 28, 2016 05:10 PM
RIKIL
Oct 4, 2015 11:44 AM
Blue and White
Jan 1, 2012 05:34 PM
