tow package
Old Sep 26, 2009 | 07:49 PM
DMAN's Avatar
DMAN
tow package
I have a 97 f250hd. It has the factory wiring for trailer lights with a 4 prong plug. So I bought a brake controller and the plug to go to the factory wiring under the dash. I also bought a 7 way plug that plugs into the 4 prong and than you wire the extra wires. I found the extra wires under the truck but I only get power from the brake controller. No 12 volt or back up lights. So I looked under the hood and found the wire for 12 volt and back up plugged off by the fuse box. Why would ford wire the rest and not the auxiliary? How can I complete it?
Old Sep 26, 2009 | 08:12 PM
IowanStraight6's Avatar
IowanStraight6
It was just one of those design flaws, on all of them i have seen including dads they run a 12volt fused right from the battery and tie into the reverse lights in the back
Old Sep 27, 2009 | 04:38 PM
DMAN's Avatar
DMAN
I guess I'll just hook a relay in and run the wire to the batt.
Old Sep 27, 2009 | 06:24 PM
Diesel_Brad's Avatar
Diesel_Brad
If you put relays in the under hood fuse box you will have 12v to the assesory and back-up pins on the trailer plug
Old Sep 27, 2009 | 09:00 PM
DMAN's Avatar
DMAN
Were do you put them in?
Old Sep 28, 2009 | 05:35 PM
Diesel_Brad
In the under hood fuse box. If you look in your owners manual it will show you where exactly
Old Sep 28, 2009 | 07:51 PM
DMAN's Avatar
DMAN
The wires dead end and have a dummy plug in them before the fuse box. Hooked up a relay and ran it to the battery today.
tcrbraydn
28
Sep 23, 2020 07:28 PM
EricNCSU1204
24
May 4, 2017 07:18 PM
2000f-1507700
18
Apr 1, 2017 03:09 PM
nalts
Electrical Systems/Wiring
22
May 15, 2013 01:02 AM
FordTrucksKickGM
All Things Towing
Jan 9, 2008 03:25 PM
