frame boxing plates
Old Sep 26, 2009 | 07:03 PM
bsteele52's Avatar
bsteele52
frame boxing plates
What thickness of metal do I need to box my frame for MII install? (50 f-1)
Old Sep 26, 2009 | 07:30 PM
LEckart's Avatar
LEckart
A thickness no less than the thickness of your original frame material. Most use 1/8 or 3/16. You can cut it yourself, make patterns and have it cut at a metal shop, or purchase metal already cut for your application. Just depends on what tools you have and how deep your pockets happen to be.
Old Sep 26, 2009 | 07:55 PM
bsteele52's Avatar
bsteele52
Thanks, I have a friend that owns a welding shop and has some scraps I can pick through.
Old Sep 26, 2009 | 09:09 PM
3golfjack's Avatar
3golfjack
My MII crossmember came with 3/16 thickness. And use some cardboard are stiff paper and make patterns because the height of the rails do vary. Leckart was dead on it.
Old Sep 26, 2009 | 10:13 PM
rtcalabrojr's Avatar
rtcalabrojr
Darksider
I just did my c-notch on my 55 f1oo and used 3/16 plate. It was the same thickness as what was used on my Mustang II install. Good luck!
Old Sep 27, 2009 | 04:23 PM
49fordpickumup's Avatar
49fordpickumup
Could anyone add comments about drain holes and so called lightning holes in the boxing plates. This is if you run boxing plates the full length. chuck
Old Sep 27, 2009 | 04:42 PM
LEckart's Avatar
LEckart
49fordpickumup-
I think that is personal preference. It seems to me more debris could get trapped behind the boxing plates if you did the lightning holes.
YooperUno
Feb 10, 2016 07:44 PM
307-Niner
Jan 11, 2016 07:48 PM
badaz4570
Jul 18, 2015 12:24 PM
candoo
Apr 14, 2015 09:15 PM
48 Steel
26
Aug 16, 2007 08:48 PM
