Offroad & 4x4
custom axles needed
Old Sep 26, 2009 | 05:15 PM
bloodhound51's Avatar
bloodhound51
custom axles needed
long time no talky
I want to make an IRS setup out of a 9 inch ford. Looking for a 31 spline shaft with a u-joint yoke. Shafts will be 8-3/32" and 10-3/8" length. dana 44 outer maybe????
Old Sep 27, 2009 | 12:06 AM
75F350's Avatar
75F350
DUtchman makes center sections with u-joint style stubs or CV style.
http://www.dutchmanms.com/1_irs_centers.html
Old Sep 27, 2009 | 06:22 PM
bloodhound51
appreciate the info
vince
Old Sep 28, 2009 | 12:59 AM
muscletruck7379's Avatar
muscletruck7379
what exactly are ya buildin' there vince?
Old Sep 30, 2009 | 07:43 PM
bloodhound51
FORD powered sandrail. I hate transaxles so im working on this 9 inch IRS. I wanted to keep the trailing arm suspension. Shooting for 12-14" of wheel travel in the rear. Im running a Mild 408 windsor in the rear(DART 195 heads). Powerproducts drop box to redirect the power to the rear. Im no tighta$$, but im not giving $20,000 for a transaxle that will hold up to a v-8.
Not a ford truck so I posted this in the off-road forum.
vince
Old Sep 30, 2009 | 07:52 PM
1966Tbird's Avatar
1966Tbird
how do you like those dart heads i was looking at a set of them for my 306 but ended up with the trickflow fast as cast 190cc heads, did you have to do a lot of work to them other than change the springs before you put them on?
Old Sep 30, 2009 | 07:53 PM
Prozon's Avatar
Prozon
Well sandrails are generally used off-road. So its all good.
And being ford powered.. I want more information!
Why don't you keep us updated on the build?
Old Sep 30, 2009 | 08:01 PM
muscletruck7379
sounds wicked, have you considered using cv axles?
Old Oct 1, 2009 | 05:22 PM
bloodhound51
I'll keep you posted. Yes I have considered CV joints, but with my wheel travel goals and axle lengths I think u-joints will do well.
Far as info on the build. I have a torch, grinders, chopsaw, drill press, and small hand tools to keep it square. The one thing I do have plenty of is welding equipment. Rollcage is 1-3/4 DOM tube with 1" HREW pipe triangulation. All the fishmouthing was done with a hand grinder. I'll post some pics soon of the chassis.
I like the DART heads, but the Trickflows have my vote. I bought the heads as a bare casting and put in decent valves and springs. The motor is not real extreme reason being that it should weigh around 1700 lbs when totally dressed so 350 hp will move it better then average.
Old Oct 1, 2009 | 05:44 PM
Prozon's Avatar
Prozon
Well it sounds pretty awesome.
I'll be sure to take a look as soon as you get some pictures up!
Old Oct 3, 2009 | 01:31 PM
bloodhound51
Found a brake hub to use on my trailing arms. Its a dana 44 hub that uses a 31 spline stub. $50 at local auto store uses factory brake calipers and rotors.
Old Oct 3, 2009 | 01:49 PM
bloodhound51
found a half shaft
Old Oct 3, 2009 | 11:32 PM
Prozon's Avatar
Prozon
So what about some chassis pictures?
AXracer
18
Feb 28, 2015 10:26 PM
mljs54
16
Mar 27, 2014 01:38 PM
fbb1951
Jan 15, 2014 07:26 PM
dclowrider
Oct 27, 2013 12:23 PM
RUSTY50F1
28
Oct 19, 2007 05:58 PM
