Heater not working so well....
Old Oct 30, 2002 | 03:25 PM
Doughboy55's Avatar
Doughboy55
I just got a call from my wife that the heater on her '99 Expy works fine until she stops. Sitting at a stoplight the heater blows cold air. Any thoughts?
TIA
Old Oct 31, 2002 | 11:35 AM
PaulC's Avatar
PaulC
Is this an XLT with the three-dial HVAC system or an EB with the electronic climate control? If the former, I would verify that the coolant level is ok. Usually, heater hoses are the high point of a car's cooling system. If coolant is low, the water pump may be able to push coolant through the heater core when the engine is operating at driving speeds. At idle, the pump will not generate enough force to cause circulation through the core; the heater fan immediately cools the stagnant water and cold air is the result.
Old Oct 31, 2002 | 12:57 PM
PaulC's Avatar
PaulC
As an addendum to my last post, I would check the coolant level regardless of the model in question.
Old Oct 31, 2002 | 01:17 PM
PaulC's Avatar
PaulC
