Power Stearing Line failure
Old Oct 3, 2009 | 08:47 AM
screech.owl's Avatar
screech.owl
I too blew that hose and had to replace it. In fact I screw up the first replacement hose because it cross threaded. What I finally did is take off the air conditioning comp. and p/s pump assembly, It seems like alot of work but it was a piece of cake compared to trying to fumble around inj that tight area. My only problem now is the new fluid has a strong burning smell and my p/s sticks. I replaced the p/s pump and flushed the system. Any suggestions?
Old Oct 3, 2009 | 08:55 AM
Talyn's Avatar
Talyn
i had some nasty fluid in there also.
did you get the air out of the system?
You have to turn the wheel back and fourth all the way while its running a few times.
check the PS fluid and do it again.
Old Oct 3, 2009 | 09:00 AM
screech.owl
Thumbs up
My project today. Thanks for the advice. This forum is great.
screech.owl
Old Oct 3, 2009 | 09:26 AM
Talyn's Avatar
Talyn
Yea, just gotta get the air out. It will be jumpy while you purge the system turning the wheel back and fourth.
Old Oct 4, 2009 | 12:22 AM
stevorino's Avatar
stevorino
Use an open ended box wrench from the wheel well or go in trom the top with a really long extension and a crow's foot from behind the a/c compressor. It is a pain but these are the best tools for the job. I had to replace mine and I ended up having to use teflon tape on the threads at the gear box to keep it from leaking. I highly recommend threading by hand first before trying to force it in with a wrench.
Old Oct 4, 2009 | 11:03 AM
Talyn's Avatar
Talyn
Yea, it took me all the time to just get the threads started.
After that it was 15 seconds to wrench it down though the wheel well with the wheel off.
I stopped using tape and use the liquid stuff.
Its the awesome!
Old Oct 4, 2009 | 04:02 PM
stevorino's Avatar
stevorino
I like the liquid for household use, but I fear it will contaminate the fluid on the truck so I used the tape and kept it away from the end of the nut.
Old Oct 4, 2009 | 04:10 PM
Talyn's Avatar
Talyn
stuff dries super fast.
and resists just about everything i've put on it.
When you go to take it off, its just like pealing off the tape, but harder to get off.
