which transmission?
Old Sep 25, 2009 | 10:35 AM
andyman7931's Avatar
andyman7931
which transmission?
going to look at a parts truck tomorrow, it's an 86 f150 that has a 4 speed manual. What transmission might it have and how can I tell the difference? What options were there? I'm guessing a NP435, T18 or a SROD, am I correct?
Old Sep 25, 2009 | 12:30 PM
bghnkinf250's Avatar
bghnkinf250
NP 435 has an aluminum cover, T-18 has a cast iron cover, and the is all aluminum. If I am not mistaken, I believe the SROD also has external linkage. That is the quickest/easiest way to tell.
Old Sep 25, 2009 | 01:19 PM
85e150's Avatar
85e150
SROD in a PU will have a turret and internal rail. (Single Rail Over Drive)
Vans use the external linkage jobs, not sure where else they appeared.
You are correct about which ones you are likely to find.
Pics of the transmissions in question here, along with other id info for the BW boxes:
http://www.motivegear.com/tech_info/...nny_guide.html
That '86 should have a juice clutch and a weak firewall. Check for any parts you might could need in that department, and see if the factory firewall reinforcement is available too, if you have an '80s truck....
Old Sep 25, 2009 | 07:58 PM
andyman7931
The manual truck I looked at tonight I think had the t18 based on comparing it with pictures online. Reverse was next to 4th gear and there was a PTO port on the passenger's side. I think it was also cast iron, but hard to tell based on a quick glance in the rain. Also, first gear was granny low and starting in second was much easier.
my truck is an 89 model. I have a c6 in it now but want a manual shift transmission. I do a lot of hauling and don't want a weak transmission. Is this an upgrade for me? I have a mildly upgraded 351 under the hood.
Old Sep 26, 2009 | 02:18 AM
85e150's Avatar
85e150
As transmissions go, a C6 is just about as stout as it gets.
With a manual, you have other considerations when doing heavy hauling. Clutch quality is important. U-joints and axles take a beating if you aren't smooth with a manual.
The low first is good, but the torque converter in the automatic accomplishes nearly the same task in most applications.
So think about the work involved and the cost. If you have a good functioning C6 now, and replace it with a good functioning manual, you are really not gaining or losing much, just making a change.
Old Sep 26, 2009 | 05:10 AM
andyman7931
yeah, I have been thinking about the amount of work involved. The cost isn't a concern since I'm getting the parts for almost free. I'd freshen up the transmission while it's out, so that's only $150 or so. The donor vehicle has an almost new clutch on it as well. The biggest investment I will have in this is time, which I don't have a lot of lately.
My current issue with my transmission is the heat it generates while pulling up hills. I have to slow down significantly to not let the c6 get too hot. I feel that the torque converter since it doesn't lock is robbing me of power and heating up the fluid. The manual transmission should eliminate that. The c6 has so far had enough grunt down low to get the load moving without issue.
I'm confused with this, if it was a zf 5 speed, I'd do the manual swap without question, but since it's the 3 speed with granny low... As stated, I'm not gaining much.
Old Sep 26, 2009 | 07:47 PM
85e150's Avatar
85e150
Not sure about buying it here, but $100 gets you lunch, beer and one of these:
http://www.amazon.com/gp/product/B000C39C9A
Old Sep 26, 2009 | 08:18 PM
rhodie's Avatar
rhodie
I have not used a t-18, but it seems to be a highly regarded (and heavy duty) tranny here on this forum (as is the c6). There is a good tech article on doing a refresh for the t-18 on the forum as well--should you choose that road.
Old Sep 26, 2009 | 09:07 PM
andyman7931
got one already. I am going to add a second one once I remove my AC. I'm also going to get a deep tranny pan to hold more fluid.
I think I'm going to stick with the c6, I'll still keep the parts for the manual swap so if the auto tranny dies, I'll do the swap. Thanks for the input
Old Sep 28, 2009 | 12:05 AM
Maddragoon's Avatar
Maddragoon
86 f150's also had the tremec t170 rts 4speed 4th being overdrive. its a pretty good light duty aluminum transmission. i've put mine through hell this year and the gears, forks, seals and case are still in excellent condition. banging in out of gear because of a weak clutch mount hasnt been good on the synchronizer keys though.
its not a speedy tranni or an overly strong one either but with the overdrive i can squeaze about 22 mpg out of her. thats with a 4.9 I6 though. but when you into account she is a 4x4 with 33's i'd say thats pretty good milage. mid size small block like a 351 would probably net about 18 mpg max.
Old Sep 28, 2009 | 12:21 AM
85e150's Avatar
85e150
See reference to the SROD above.
I wouldn't do a bunch of work to install one of those. Not very strong, and the 2nd to 3rd gap is very wide.
Old Sep 28, 2009 | 01:17 AM
bghnkinf250
I prefer the T18 or NP435, as I like to do my own shifting, but as stated before, the C6 is as good as you can get!
Shadowrider123
Sep 12, 2019 01:35 PM
triguy450
1997 - 2003 F150
Jun 8, 2016 11:53 AM
King Windsor III
Apr 21, 2015 03:55 PM
rhymesconnie
1997 - 2003 F150
Jul 13, 2014 08:59 PM
