glow plug light comes on while driving
Old Sep 25, 2009 | 12:14 AM
mybigredford's Avatar
mybigredford
the title pretty much sums it up, once in a blue moon i will be driving and look down at the dash and see that my GP light is on, and i know the plugs are not on because my volt gauge doesnt show it. if i stop and shut the truck off, fire it back up, no light and good to go. any ideas, everything seems fine with the truck, i just keep driving if i see it on. i think this has happened maybe 5 times in the last year.
anyone else have this happen and do i have a problem or maybe just a loose wire somewhere?
Old Sep 25, 2009 | 12:22 AM
mndiesel's Avatar
mndiesel
Maybe you have a wire that is exposed to the relay and it is contacting metal. That would cause the light just like it is energized. Someone else with more knowledge will chime in soon.
Old Sep 25, 2009 | 08:06 AM
Ponyboychris's Avatar
Ponyboychris
Hmmm, your glow plug light (aka wait to start light) on the dash is controlled by the PCM and doesn't reflect the true operation of the GPR. In another words, your GPR and glow plugs are on longer than the dash light is. Are you having any other electrical issues like flickering battery light or CEL?
Old Sep 25, 2009 | 08:15 AM
robs01f250's Avatar
robs01f250
check for exposed wires under the hood. Something could be shorting out. Is the wait to start light coming on when before you start the truck?
Old Sep 25, 2009 | 12:32 PM
duck fan's Avatar
duck fan
Because racetruck
Are you sure its the glow plug light and not the light for the filter minder?
Old Sep 25, 2009 | 01:05 PM
87 F-150 I6's Avatar
87 F-150 I6
The PCM controls the glow plugs, and like Chris said the light dose not mean the glow plugs are one. I would check for chaffed wires under the dash and around the GPR. You also might have some other electrical issues going on.
Old Sep 25, 2009 | 09:00 PM
clintbonnie's Avatar
clintbonnie
Check for fault codes..
Jason2113
Apr 27, 2017 04:00 PM
Collision
Dec 24, 2016 07:21 AM
hurst1979olds
17
Nov 30, 2016 09:53 AM
tkloppel
Oct 27, 2011 06:18 PM
dylan8427
Jan 17, 2011 12:54 AM
