Difficutly to replace wheel seals and Diff Seal
Old Sep 24, 2009 | 10:37 PM
RedDirtLandscaping's Avatar
RedDirtLandscaping
I need to replace the wheel seals and the front seal on the differential of a 69 F100. Someone told me I need to remove the entire rear axle. What is the simplest way to do this? Thanks!
Old Sep 25, 2009 | 06:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by RedDirtLandscaping
I need to replace the wheel axle seals and the front pinion seal on the differential of a 69 F100.
Whoever told you to remove the rear end to replace the pinion and axle seals is full of scheiss.
I wouldn't believe anything this duffus says!
I suggest you get yourself a Chilton or Haynes shop manual which will walk you thru the procedures.
To replace axle seals, you have to remove the rear brake drums, brake backing plates and pull the axleshafts out.
To replace the pinion seal, the companion flange has to be removed first.
Even if you did pull the rear end, you would still have to go thru these same procedures.
Tuna Maniac
Mar 6, 2017 02:32 AM
Mike1
Nov 30, 2016 09:52 AM
Knewstroke97
Nov 28, 2014 07:43 AM
FordOwnerJoey
Nov 6, 2013 02:30 PM
stephen.south
Feb 28, 2012 12:53 AM
