Dash Cluster
Old Sep 24, 2009 | 07:15 PM
stang74shelby's Avatar
stang74shelby
Dash Cluster
Every one seems to say that a 94-95 cluster cant be put in a 93 (not charging)..... I put a 95 cluster in my 93 with some mods.... I used the gauge internals and needles from the 93 and transplanted them in the gauge face of the 95 (the resistance measured different on the gauges). Once you put the gauges in and before putting needles on install the dash and turn key on (the Oil pressure, Temp (eng cold) will zero) can put needles on those at that time. My rear tank leaks so its empty flipped switch to rear tank and gave it a min, put the needle on for empty setting. For the volt meter once ya turn the key off it zeroes. Had to use my Speedometer since the newer one was defective. I hace no Airbag so if you have it wiring will change a little. Also had to rewire the connectors..
Had to remove the wire from pin 14 (bk) of C250 and tape it off (not used)
had to move wire from Pin 12 (r/lg) of C251 and put it in pin 14 of C250
had to move wire from Pin 11 (lg/r) of C251 and put it in pin 1 of C250
had to remove wire from Pin 14 (r/y) of C251 and tape it off (not used)
had to swap wires on C251 Pins 2 (dg) and 3 (pk/lg).... they are reversed.
After completion works great.
Old Sep 26, 2009 | 08:13 AM
stang74shelby
Hope you all can use this info.
