1978 - 1996 Big Bronco
rear end gear
Old Sep 24, 2009 | 03:36 PM
ohioj's Avatar
ohioj
rear end gear
would anyone know what the rearend gear ratio is in an 85 bronco?
Old Sep 24, 2009 | 04:04 PM
g_k50's Avatar
g_k50
There's a tag on the axle, on one of the bolts, take the tag off.
You should see a 3.55 or 4.10 or a similar number on it, on my 1990 Bronco it was the bottom left number 3.55, you can see a picture of it in MyGarage, under DonKo.
Also there's a tag in the door jam that has an axle code, look up that code in a Haynes or Chilton or a 1985 Service Manual.
Old Sep 28, 2009 | 11:05 AM
Kemicalburns's Avatar
Kemicalburns
if it has a ford 9" then it will be 3.50's and if its an 8.8 with a 302 or 351w it will have 3.55's this was the most common ratio. if you have a 300-6 some had a 3.08 gears also
Old Sep 30, 2009 | 09:49 PM
Aciancio's Avatar
Aciancio
what is the axle code on your door post?
