Adding to Keyed Power
Old Sep 25, 2009 | 12:03 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Originally Posted by TheKirbyMan
I was actually wanting to do this same exact thing!
81-F150, which vehicles did these safety relays come on? And do you know which amperages they're available in?
All types. Mostly 1970's and 80's F-series pickups with certain options. Aux battery, Trailer and Camper specials, all had safety relays.
They can be bought aftermarket as well. Which is what I would do.
They can be rated anywhere between 10 amps and 100 amps. But am not sure which are rated which.
Old Sep 25, 2009 | 12:09 PM
bghnkinf250's Avatar
bghnkinf250
Mine is only 40 amps, but I am only using it to control other relays for lights and other add ons.
Old Sep 25, 2009 | 12:22 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
Contactors are bigger "relays" where usually a block of contacts move together. A relay is usually a set of spring contacts that warp to make contact. Anyway, here's a pic of the solution for me, once I find a place to mount it. One relay each for high beam, low beam, l. turn. r. turn, 4way, and running lights. All fed from a 30 Amp upfitter switch. (By the way, the upfitter switch relay panel has a ground wire that can be switched to disable all the upfitter switches at the same time).
Old Sep 25, 2009 | 12:25 PM
bghnkinf250
That looks good!
Old Sep 25, 2009 | 03:06 PM
Bern_F150_4x4's Avatar
Bern_F150_4x4
Originally Posted by bghnkinf250
Keep the hand off the shifter. That accelerates wear on the shift forks on the trans. I have seen it a lot.
Good Point, DOH
I really need to pick up an arm rest with some drink holders...
Old Sep 25, 2009 | 04:11 PM
86bigred's Avatar
86bigred
I wired my off road lamps into through a relay that's triggered with the high beams. My off road lamps are 150 watts.when my high beams are on I can flip a switch and turn them on,and when I dim my lights they go off automaticly.
Sooper Camper
Jul 7, 2013 06:22 PM
Rusty_S
General Automotive Discussion
Dec 8, 2010 01:42 PM
TheKirbyMan
15
Dec 5, 2010 11:26 PM
TheKirbyMan
'80-'86 FAQs (Frequently Asked Questions)
