Battery volts...
Old Sep 23, 2009 | 07:23 PM
6litrefan's Avatar
6litrefan
Battery volts...
I did the self diagnostic test mode thingy where you hold the reset and setup button down at the same time then turn the key on and you can do a gauge sweep and check for codes and alot of other info.....and my battery voltage was showing 13.8 volts in that screen....is this an accurate indicator or? and does that sound right for a good set of batts?
Old Sep 23, 2009 | 07:32 PM
69cj's Avatar
69cj
I can't tell you since I always seperate the batteries and do individual battery tests. Never done it your way.
Old Sep 23, 2009 | 07:52 PM
liv's Avatar
liv
Sounds pretty normal but you really need to test each battery individually. One battery can hide the others problems if you do it that way. Keep in mind that your voltage is going to be lower than optimal until your glow plugs kick off which will take a little while. Your going to want to shoot for as close to 14.4 volts as possible
Old Sep 23, 2009 | 10:41 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke
Never knew you could do that. I'll have to try it. Without the motor running...a fully charged battery sits at 12.6V...while running...I would agree with liv...shoot for at least 14v. What codes and other info do you see?
Old Sep 23, 2009 | 11:49 PM
ford7379trucks's Avatar
ford7379trucks
13.8v is normal
Old Sep 24, 2009 | 07:21 AM
UGA33's Avatar
UGA33
That is a normal reading.
Old Sep 24, 2009 | 11:12 AM
eddiedebb's Avatar
eddiedebb
What is the "self diagnostic test mode thingy where you hold the reset and setup button down at the same time "?
1953FlatJohn
New Member Introductions
Oct 9, 2017 11:38 AM
tom1940
Sep 17, 2014 08:00 PM
KDAVID1
Jun 3, 2014 09:37 PM
abe
May 31, 2014 12:08 PM
Greywolf
All Things Towing
27
Feb 22, 2014 06:28 AM
