Volts low at start
Old Jun 3, 2014 | 03:23 PM
KDAVID1's Avatar
KDAVID1
Volts low at start
Don't know if this is related but after I did the blue spring yesterday I noticed today my volts lower at start than before and take a bit longer to get up on volts when on the way? My batteries about to die?
Old Jun 3, 2014 | 03:31 PM
vatreefarmer's Avatar
vatreefarmer
How low? The 6.0 is notorious for having minimalistic alternators. My 06 will display voltage below 12 at idle until after the first minute.
Old Jun 3, 2014 | 03:56 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Originally Posted by vatreefarmer
How low? The 6.0 is notorious for having minimalistic alternators. My 06 will display voltage below 12 at idle until after the first TWO minutes.
Fixed it for ya.....
OH...it's not the alternators...it's the glow plugs!
Old Jun 3, 2014 | 06:04 PM
KDAVID1's Avatar
KDAVID1
Gotcha. Seems fine now and I was probably just a little jumpy after doing some work and something seemed different. I did figure out what is different---I am not hearing the buzzing now when I turn the key on--koeo? I assume that is the buzz test? Engine starts and runs fine and the only thing I have done was an oil change and blue spring update.
Old Jun 3, 2014 | 06:53 PM
Jmoen7's Avatar
Jmoen7
Buzzing is Injectors and/or fuel pump, normal stuff
Old Jun 3, 2014 | 06:54 PM
KDAVID1's Avatar
KDAVID1
I know--that's the thing I'm NOT hearing the buzzing now?
Old Jun 3, 2014 | 07:00 PM
Jmoen7's Avatar
Jmoen7
Let the truck settle and cool off and KOEO again, could be that you started right after a shut down and the system was already primed before you could hear it
Old Jun 3, 2014 | 07:13 PM
KDAVID1's Avatar
KDAVID1
could be it--new oil change went to T6 5W40 and it's in the high eighties low nineties here--maybe the system is working better now?
Old Jun 3, 2014 | 07:21 PM
Jmoen7's Avatar
Jmoen7
Not sure oil weight or mileage on it has anything to do with it, that would be news to me. Fuel system should buzz/prime on every KO until primed 100%, whether or not it holds its pressure for a certain amount of time after shut down i don't know.
Old Jun 3, 2014 | 07:28 PM
diesel_dan's Avatar
diesel_dan
KDAVID1: The bluespring and low volts are unrelated. You never did answer the "how low" question on your volts?
It definately is one of those things we want to stay on top of: battery health, Alternator output, FICM voltage all add into the: how long my injectors live equation (well and there's other stuff too ), but going to 5w 40 synth is a good thing...
Old Jun 3, 2014 | 07:33 PM
vatreefarmer
Perhaps I need a flash? I do not, nor have ever had, the injector buzz flash. I don't think it was standard issue when my truck was mfd
Old Jun 3, 2014 | 07:38 PM
diesel_dan's Avatar
diesel_dan
I think before I paid Ford to update my FICM flash version I'd look into some other options of maybe having the FICM gone thru plus latest flash plus maybe the PHP Eco tune. My $.02 worth...
Old Jun 3, 2014 | 07:44 PM
KDAVID1's Avatar
KDAVID1
sorry--saw 10.5 first thing this morning when starting. ficm stayed steady 47.5 when starting. volts starting the rest of the day were above 12 and above 13 to 14.5 while driving.
it was just odd not to hear the injector buzz.
Old Jun 3, 2014 | 07:59 PM
diesel_dan's Avatar
diesel_dan
You are heading in the right direction -- any idea how old the batts are? The Alt volts sound good...
Old Jun 3, 2014 | 08:02 PM
BLADE35's Avatar
BLADE35
10.5 not bad if the gauge updated during the actual crank
you do probably have a battery cell going down
Mine usually gets to 12.68volts within 6-10seconds after crank at Idle Temp kinda plays
