I believe that maybe Ford made a 400 performance motor. I would question it being in a F-250 2wd truck in 1976. I am going to research it a little and see what I can find about it. I'd be interest in the engine code from the truck.
i have a 79 not 76, and the 400 was one of the most common motors in ford trucks. But the 2 gallons per mile, was because i had a serious gas leak out my diaphram, and my engine was pissin out more gas than it was burning. but i got that all taken care of.
You guys don't have a clue. Ford never made a "big" block or a "small" block. You have been hanging with the chebby guys too much. There is indeed a 351M engine, but Ford never called it a modified or any thing other than a M.
Some of the engine blocks are bigger than others but Ford never called them a big block or a small block, but rather grouped them in engine familys or series.
The 351M and 400 share the same engine block and heads but use a different crank and pistons to acheve the additional cubic inch displacement. The 429 and 460 are the same story.
The 351M, 400, 429 and 460 all share the same bell housing bolt patern, but are in different engine series.
While a 460 is a "big" block when compaired to a 302, so is a 351M or a 390. If you want to refer to Ford engines by size, you would need very small, small, medium small, medium, medium large.........
As far as fuel milage goes there is always one important thing to look at.... And that is how heavy your right foot is... I have a '73 high-boy with a warmed over 390 in it... and if I milk the throttle and shift early I can squeese 16 mpg out of it... but since it has a very vocal exaust note... for me it is hard to keep my foot out of it... So I normaly get around 8 mpg... Granted that is 8 mpg up hill, down hill, towing, being towed, and even parked... So yes keeping your truck in tune will help your fuel milage but not as much as just keeping your right foot light...
Also bit of a side note... a quote from one of the last threads about fuel milage that I read on this page:
"gas stations are stratigicly placed just for old ford pickups..."
There were plenty of 400s in the 70s Ford trucks. I find them more common than the 390's actually. The reason your losing fuel economy on yours is the tire size cam heads and everything else is a race set up. I would consistently get around 14 out of my 85 F150 with a 351W and C6. Its just a matter of setting the truck up properly. Plus like previously stated the 351C is not a big block it is a small block as is the Winsor engine line.
ford did call it the 351M. but the "M" stands for "modified" because it was not the 351C. and you are right about the engine sizes, but for general conversation, cleavland and windsor based blocks are referred to as small, and FE and bigger are big.
ford did call the 351M "351modified" (not midland or anything else) there was a large argument about this not long ago. numberdummy has the evidence to prove it, i dont remember what the thread was called but if you find it everything will be explained. although big and small block are not a technically ford terms, as far as i know, certain engines are generally referred to as such.
You guys don't have a clue. Ford never made a "big" block or a "small" block. You have been hanging with the chebby guys too much... Some of the engine blocks are bigger than others but Ford never called them a big block or a small block, but rather grouped them in engine familys or series...
What are you talking about? The chebby guys got the 396... the big-block, the 454... the bigger-block, and the 502... the biggest-block
Well dannit I got a 460 in my truck and it's the big'un therefore I'm gonna call it a BIG BLOCK regardless of what Ford wants to call it
Besides... "the 385 series"? You say that and people go, "What the hell is that? Ford never made a 385!" I'll stick to "big-block" thank you.
