Turbo question
Old Sep 23, 2009 | 06:20 PM
throwdown's Avatar
throwdown
Turbo question
As soon as all my parts get here I will be installing the RiffRaff CCK and WW.
I also plan to do up pipes as they are leaking like crazy. While I've got it open, I am going to do the .50 mod and retorque under the valve covers, as well as foil delete. I figure I will need to pull the turbo to do the up pipes so I may as well do an O-ring kit and do it right.
My question is.........Should I replace the turbo bolts just as a matter of course, and what, if any, locktite should I use?
Old Sep 23, 2009 | 06:31 PM
Izzy351's Avatar
Izzy351
I don't think you need new bolts. I reused mine last year, and it's been leak-free all this time. And I didn't use any Loctite on the two hold-down bolts. Just on the housing bolts. Blue on the compressor side, and red on the exhaust side.
Old Sep 23, 2009 | 06:38 PM
tdpower's Avatar
tdpower
You probably know this but with the foil delete you are going to hear turbo whistle in the cab. Along with the 6637 mod it is probably going to be noisy.
Old Sep 23, 2009 | 06:48 PM
Izzy351's Avatar
Izzy351
Yep.
Old Sep 23, 2009 | 07:03 PM
duck fan's Avatar
duck fan
Because racetruck
I assume you mean the FRx. Great product, love mine.
Old Sep 23, 2009 | 07:07 PM
robs01f250's Avatar
robs01f250
yea but I really like the sound of the foil delete and the 6637 combination
Old Sep 23, 2009 | 08:05 PM
throwdown's Avatar
throwdown
Your right Duck Fan, I do mean FRX.
Thanks for the Info Izzy 351
