Brake Issues PLEASE HELP!
I have been working on a brake issue on a 1995 f350 DRW for some time now. I am at the point of just giving up because I have no where else to turn. Here is what's happening, this truck has only RABS disks in the fromt drums in the back. With the truck off and all the vacuum blead out of the booster the pedal is solid as a rock as it should be. I start the truck and build vacuum and depress the brakes, I get one press with a "normal" pedal and then as if I was at a stop light I hold my foot on the pedal and it slowly creeps to the floor. If I pump the pedal a couple of times it starts up high again and then repeats itself again. Here is what I have done,
1) new brake lines steel and rubber all around.
2) 6 new master cylinders.
3) new brake booster.
4) new rear drums, shoes, spring kits.
5) new calipers, pads.
6) new RABS valve under driver seat.
I have blead the entire system over and over again and it will not change a thing. The vac is producing 23 hg but the recovery timie when the vacuum is depleted is slow to return back to 23 hg. I also read a few things about the RABS system and have checked the fuse and the sensor in the top of the pumpkin all seems to be initact and working as advertised. I also ran a "diognostic test" on the RABS by grounding the orange and black wire under the dash. I got 16 blinks total telling me that everything is ok with the RABS. Another thing I have read about this kind of issue is problems with the third brake light???? I took it off and found that the bulb was bad and the socket was slightly melted but not enough to create such a problem. I'm not sure where to trun next and for all the posts on the web I have read there hasn't been one that I hve read that pin points how to fix this problem. It seems that every guy that has had this issue has change one thing or another and it either fixed it or didn't. I'm kinda sick of trial and error isn't there a way to trouble shoot down to a component? HELP!!!!!!!!!!!!!!
Also , a new master cylinder needs to be bench bled ...( I have seen re mans that weren't any good also)...
1. Reverse the order of the bleeding procedure. Closest first farthest last. This worked for me on the 86 when I had a similar issue. Using a second person in the cab apply pressure to the pedal and bleed. Do not pump the pedal. Keep the reservoir full as you go. See if it helps.
2. Gravity bleed. I have never done this myself. I have read about it a couple of times. Can't say where to start with this method but front to back seems most logical to me. I'm sure you have some hose that will fit over the bleeder valves. Open each valve and let it drain keeping the reservoir full as the level drops. You can figure the rest out. It takes allot of time but at this point what the heck. Its only brake fluid.
Thats about all I've got off the top of my head. If I come up with anything else I'll let you know.
Pardon us for not welcoming you to FTE!
Welcome!!!
sorry this isn't any help but at least I feel your pain
The gravity bleeding takes a long time. Fill the Master Cylinder with brake fluid, open the bleeder screws on all four wheels and keep checking the fluid level.
If you look at the module there is a large hex bung on the end of it. Unscrew the bung (against spring pressure all the way) and remove the spring that is behind it (no fluid will come out). Replace the bung and pump the pedal a few times to fill the chamber.
If the brakes are now good then the module is faulty. If still the same then replace the spring and and look elsewhere.
After installing the first and 2 master cylinders I recieved 3 and 4 master cylinder and dissasembled them first before installing them in the car. 3 was missing a seal all together and 4 had a load of sand blasting sand in it. The 5th was built properly and worked fine.
the brand is fenco that I had problems, check the rabs like mention on the post above me.
Got this information from a tech. service bulliton. 98-5A-34
F6TZ-2140-BA with cruise
F6TZ-2140-AB without cruise
This has nothing to do with your problem, I'm only mentioning it if you decide to go the route of replacing your master cylinder again and to get a bit of a brake upgrade.
98-5A-34
03/18/98
BRAKES - HIGH BRAKE PEDAL TRAVEL OR LOW
BRAKE PEDAL FEEL
LIGHT TRUCK:
1995 F-250, F-350
ISSUE:
The brake pedal may feel low or there may be long brake pedal travel on some vehicles. This may be due to the master cylinder bore size.
ACTION:
Replace the master cylinder with a revised master cylinder which has a larger bore to displace more brake fluid when braking. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
1. Perform the diagnostics outlined in the 1995 F-Series Service Manual, Section 06-00 for long brake pedal travel or low pedal.
2. If adjustment is unnecessary or does not correct the concern, replace the master cylinder. Refer to the 1995 F-Series Service Manual, Section 06-06 for removal and installation procedures. Refer to the Application Chart for correct part usage.
PART NUMBER PART NAME
F6TZ-214O-AB Master Cylinder
F6TZ-2140-BA Master Cylinder
F6TZ-2140-EB Master Cylinder
F6TZ-2140-FB Master Cylinder
OTHER APPLICABLE ARTICLES: NONE
SUPERSEDES: 96-25-19
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage
OPERATION DESCRIPTION TIME
985A34A Replace Master Cylinder 0.6 Hr.
DEALER CODING
CONDITION
BASIC PART NO. CODE
2140 16
OASIS CODES: 301000
