I need to get an alignment..
Also, do I need a 4 wheel or just a 2 wheel? I've heard of people paying for 4 wheel alignments but there isn't anything to adjust back there on some vehicles..
Hats off to you too.
BJ's are no fun to replace.
If they will only set the toe then take it somewhere else, you can set the toe yourself with a tape measure. Some places that is all they can and will do on these trucks.
Myself given the choices you mentioned I'd lean hard toward the frame shop, don't have much or any faith in Belle or Firestone tire. However that would depend on the guy that would actually do the work, and then only after I spoke with him to get a feel for his skill set would I decide.
Wouldn't no minimum wage young kid with little to no experience working from a book do it no, the IFS/TTB is not a easy axle to align properly.
BJ's are no fun to replace.Firestone looks tempting, because they have a premium alignment package which includes unlimited alignments for the life of the vehicle for like $140. The 'frame shop' is $146 for a 4 wheel alignment, but if I only need a front alignment, that would almost cut that number in half I would assume.
I plan on putting 2" leveling coils and 33's on the the truck next summer, but I don't think I should wait until then for an alignment. So if I go to Firestone, I can just go back again in the spring for a 'free' alignment.
Thanks for all the advice. I'll be watchin whoever does it like a hawk, that's for sure. I still haven't decided on who to bring it too, but I know I hate giving these chain stores money..
I do recheck the toe with a tape and set it to 1/8" if it changed any after installing the new parts. I look at how the wheels sit from the front view as well, want them slightly leaning out at the top.
If all looks good and the tires are not getting stepped or scrubbed off I just run it.
And no you do not need or get a 4 wheel alignment, no rear adjustments to be made. Unless of course you have a bent frame/rear axle, or reason to think you might have that is.
When I quizzed the expensive shop before they did the work, the guy said this to me, and it put my qualms to rest:
"Look--there are a lot more easier ways for me to actually make money than to align Ford's twin-I-beam suspension. Believe me--I know! They are not easy to get right--but when I'm done, it'll be right."
And it was. The tires wore perfectly until I got rid of the truck.
Also, don't forget that your mpg will be negatively affected by a poor alignment, so even if it doesn't look "out," I would get it done.
Lastly, I'm not impressed just because they're a "frame shop." I would check with some local 4x4 enthusiasts, or other "truck guys" who you trust, as to which shop is the better qualified, for the TTB. If it is your "frame shop," then so much the better. But you might just get directed to a TTB expert, which is where I'd be headed, if I needed an alignment.
I am definitely going back to the expensive guys, if/when my "new" (to me) truck needs another alignment.
Oh, and I wouldn't expect the price to be 1/2 of the four wheel alignment price. A good shop will hang the mirrors off of all four wheels anyway, just to check for problems/damage (or just to get the shot right? I dunno....), as has been mentioned in this thread, and a significant amount of the labor is involved in just setting up the machine, even if there's nothing to adjust back there. JMO.
And definitely tell them you want a copy of the printout (as was suggested), before they do the job. I think it telegraphs your interest in them actually doing a good job....
Best of luck.
Big Six
On a side note, I just bought the truck and the previous owner said the tires on the vehicle are pretty new. The back two look brand new, the front left one looks decent, and the front right one looks horrible. There is definitely something going on with the alignment, or he didn't replace all the tires...
http://www.haroldsframeshop.com/
FYI. Here is the website to the shop. Seems legit.
They seem like an all around shop. For them to have all that equipment for service they have got to do something right. Just reading it they seem like friendly people so im sure if you have doubts they will talk to you and maybe even let you see them do a few alignments to ease your fears a bit.
I know we're just both trying to help the OP, so please don't take this the wrong way, okay?
But I really do not think the additional 100-200 lbs that the Big Six weighs, over a SB V-8, is the problem. Why?
I had (for nine years) the exact same year and model truck as you--a 1988 F-150 with SINGLE SHOCKS and the 4.9 Six. My tires wore perfectly, always, for nine years, on the one (expensive) alignment I paid for right after I bought it (described earlier in this post).
And I agree with you that the shocks are not involved, be they single or quad--shocks don't support that engine, as they're just dampers--the springs hold up the weight.
But as for the engine just being too heavy for the Twin I-Beam (or TTB, as it was known, in later years) suspension--respectfully, no way.
Again, I had the same truck/shocks/engine combo--and never had a single problem with alignment or tire wear.
Secondly, the Twin I-Beam suspension came out in the early-mid Sixties, along with the the Big Six's first iteration, as a smaller-bore 240 cu. in--but in the same block. This truck and engine combo had rougly a 30 year run together, until 1996. IF what you suggest was true, we would know it already (and my truck would have suffered the same fate).
Again, we're both just trying to help the OP, so I'm certainly not attacking YOU--I'm not attacking anything, actually--just respectfully saying I do not think your theory would apply to this situation. Though, certainly some engine/chassis combos have proven to be ill-designed, and required heavier springs, at least in some passenger cars.
I think a good front end shop, that does TTB jobs frequently (and WELL) would straighten out both of your trucks, as it did mine.
Good luck to all.
Big Six
