66-79 FE trucks what degrees is the motor leaning back ?
Hi there ...I had two questions can anyone tell me what degrees is the FE leaning backward ? I put a angle finder on my valve cover I know it's crude but it said 6 degrees leaning backwards ? I have ran my truck with the valve cover off and seen the oil.water sliding back into the pan from front to back that seems to be why it's angled for the oil to flow fast back into the pan how about the rest of the motor ?.
timing chain front bearings etc are they starving for oil ? I know Its saif Ford did a fix by giving out 6qt dipsticks to compensate for there oiling problems I'm wondering if I put my trans crosmember on backwards when I install the trans but this can't be since I had the aux gas tank and it had a bracket attached to the crosmember .
mmwade77
2004 - 2008 F150
08-20-2018 10:10 PM
Uni Moe
04-11-2014 01:39 PM
