Sponsored by: Real Truck
Rear diff amount of fluid?
Old Sep 21, 2009 | 06:33 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Alright on the 450 I need to know much much diff fluid I need. It says on the build sheet limited slip rear end but when the shop tore it apart they said that I have an Eaton locker in it So its got the 4.30 Gears in it and I don't need a friction modifier right. Also does any one know what weight oil to use?
Thanks
Nick
Old Sep 22, 2009 | 09:38 AM
weekendwarriorfsw32
Master of Strokes
Bump Any one?
Old Sep 22, 2009 | 09:57 AM
brian42's Avatar
brian42
Veteran: Navy
What axle does the 450 have? I think the duallies use the Dana 80. I think that's similar to the Sterling 10.50 I have, but I'm not sure of the Dana's exact specs. Hopefully somebody can add some info.
At least it's another bump for ya.
Tom's Avatar
Tom
Page 383 of the 2008 Owner's Guide
14 pints, 7 quarts, or 6.6 liters. 75W140 synthetic gear oil.
As for the friction modifier, here's what it says:
Originally Posted by Ford SD owner's guide, Page 386
1Add 8 oz. (236 ml) of Additive Friction Modifier XL-3 or equivalent meeting Ford Specification
EST-M2C118–A for complete refill of limited slip Ford axles. Ford design rear axles contain a
synthetic lubricant that does not require changing unless the axle has been submerged in water.
Yours is a Dana S110, rather than a Ford axle. Therefore, the way this is written I assume no friction modifier is needed. You can get a PDF copy of the owner's guide at www.motorcraftservice.com. Go to "Owner Guides" on the left, pick your vehicle, and save it for future reference. Hope this helps!
