Headlight problem
Old Sep 21, 2009 | 02:33 PM
grams72's Avatar
grams72
Headlight problem
Just got this 1989 f350 dsl and one of the issues that I have is with the headlights.
The lamps are ok as I was able to check them, the high beams work the running lights work as do the tail lights. The only thing that doesn't work are the low beams.
Where do I start to look for issues?
Would the high beam switch cause such an issue?
Old Sep 21, 2009 | 03:50 PM
bigmacmonday's Avatar
bigmacmonday
I would say either the switch or a fuse
Old Sep 22, 2009 | 02:16 AM
TexasGuy001's Avatar
TexasGuy001
It could just be that they are both burned out. I have seen that before. Thats inexpensive and an easy fix. I would go ahead and just buy 2 new bulbs.
Also, you could just check the pinouts on one of the head light connectors with a multimeter or a test light and see if there is power to one of them when the low beams is on. If there is then the bulbs are out, if not then there is another problem.
Lesalvato616
Feb 17, 2015 02:04 PM
martinraz
Aug 12, 2014 05:32 PM
aircropsinc
Dec 23, 2012 09:03 PM
Finally Powerstrokin
Oct 9, 2012 06:51 PM
goredcar
Dec 7, 2008 06:08 PM
