Starter grinding
Old Sep 21, 2009 | 02:24 PM
61 uni's Avatar
61 uni
Starter grinding
What causes this? My truck did it once this morning and hasn't done it again since.
Old Sep 21, 2009 | 05:05 PM
duck fan's Avatar
duck fan
Because racetruck
I don't have a good answer for you but here is a free bump to the front page.
Old Sep 21, 2009 | 06:59 PM
Highboosted's Avatar
Highboosted
I dunno, my truck does it probably every 10th start, done it for years. New starters and ring gear, no go. New ring gear did help it for a few months, but I think the flex plate is bent slightly.
Old Sep 21, 2009 | 07:13 PM
KelVarnson's Avatar
KelVarnson
I've heard that 7.3's are notorious for having the starter bolts come loose on a regular basis. Mine did, and so slowly that I never really noticed it was loose, until it suddenly wouldn't start at the tire shop when I went to pick it up. I borrowed a creeper and slid under there and the starter was about to fall out.
After I tightened it, it sounded like a brand-new truck. So apparently it had been loose for quite some time.
Old Sep 21, 2009 | 07:44 PM
61 uni's Avatar
61 uni
I'll try tightening the bolts then. Any idea what size they are?
Old Sep 21, 2009 | 07:53 PM
KelVarnson's Avatar
KelVarnson
Nah, I don't recall, but I would put my money on 9/16". Just take your whole socket set down there with you.
BTW I am pretty sure there is at least one thread on this subject, and it probably contains that info. I think they might have talked about using Loctite or something on the bolts also.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
