I want to do some maintenance to my new F250 to get it running tip top. What do you guys suggest? I was figuring on refurbishing the fuel system (new lines/filter) but what else can I do?
The truck has had a hard time cold starting so I just went ahead and replaced ALL the glow plugs. I know, big $$ for not much if they all work but I actually found 2 out of 8 unplugged! Now when the truck is warm, it'll start on the first crank. But it still takes forever when its cold.
I got the same problem with the cold starts and still don know what it is. As for tip top running fill the new fuel filter with seafoam fuel additive and then pour another can into the old oil drive it for 15 minutes then change the oil you have no idea how much smoother your truck will run .. I picked up about 5 mpg running it through the fuel system btw
protomor,
Welcome to FTE and the IDI diesel forum.
How long does the wait to start light come on for when the engine is cold?
Do you see the volt meter drop for about 10 seconds when you first turn the key on?
i bought it 2 years ago, when i thought the starter was shot.
then i found out it was actually the positive power cable was bad.
but i still had cold start problems. it turned out the starter was OK, but drew too muck current to let everything work properly.
i did not find it out till the starter shorted out a year later, leaving me stranded on the road.
i put the new starter in, and realized how slow the old one was actually turning the engine over
as for ease of installation, it was not that bad. a pain in the butt, but easier than putting in the new positive battery cable..
Check the insulation on the battery cable on both sides of the passenger side positive terminal.
Corrosion inside the terminal where the wires connect to the terminal is common on old cables.
When the corrosion gets bad enough, the terminal starts getting hot while trying to start the engine, and the insulation will become discolored and brittle.
The passenger side battery positive cable clamp is where all the electrical draw and charging load is connected, so a problem there affects everything.
Glow plugs draw 200 amps while heating, then the starter draws 300 amps while cranking.
So it is very important for all battery connections to be in excellent shape for the engine to start well.
Bad cables and bad connections on the cables will shorten the life of a starter.
As winter is getting closer, time to check the cables, batteries and glow plugs if you expect to have a reliable truck this winter.
how can I just replace the wires? I find ends at my local auto store but I have no idea how to hook them up to the wires so they won't come out and make good contact.
My truck still takes about 2 minutes of cranking before it starts. The starters seems to have good speed at it. The truck doesn't try to start at all though. I just crank and crank then all of a sudden its alive and kicking. I think its a fuel issue. Is the fuel pump dying? or do I have a leak somewhere?
Ok so answer was *drum roll* weeping fuel feed line to the pump. Anyone know the diameter of that line? Why oh why did ford run the fuel lines by the headers? that sounds like a disaster in the making.
