Cold Weather Starting
Old Jan 13, 2002 | 11:13 AM
rwalser's Avatar
rwalser
Post Cold Weather Starting
I know absolutely nothing about diesel engines. I am considering the purchase of a new F250 with the PSD for pulling my new camping trailer.
I know that diesels have a problem starting in cold weather. I also know that you can plug in to keep the block warm. My question, what if you are in a situation where you can't plug in when the weather is cold; how do you get the engine to start?
Old Jan 13, 2002 | 12:13 PM
BigDeezil58's Avatar
BigDeezil58
rwalser,
A Powerstroke will start. There was a post on here somewhere from a guy in Canada that does not bother to plug his in unless it's -0 degrees Fahrenheit. I live in Colorado, and although it's been a mild winter here so far, I have never plugged mine in this winter. I had a 99 PSD before, and I still never plugged it in...........Other than just for fun to see if it worked.:P New diesels are friendly. The PSD also has an exhaust restriction that warms the engine when it is started cold. You will notice it idle up a few seconds after you start it in cold weather. Honestly I would worry more about the batteries performing like they should in arctic cold. The engine will be fine. If you are still concerned, consider the V10. It has ample power to do the job as well.
Old Jan 21, 2002 | 02:10 AM
Roaring's Avatar
Roaring
relax on the cold weather starting.. just before New Years I was visitinga frind in northern British Columbia and had not plugged my truck in.. it got dfown to -22C (_14F) and I went out and started the truck.. I let the glow plugs go through 2 cycles and it started , I needed some golw plugs replaced too at the time) it chuged for a bit but smoothed out and ran just fine..... if it doesn't want to start like you are used to jusdt turn offignition and restart the secquence of the plugs a couple of times.. it will go...
good driving
Old Jan 21, 2002 | 01:26 PM
Monsta's Avatar
Monsta
Sit. Stay.
What's this!? A PSD owner giving praise to a gas engine! Somebody told there were guys like you! I didn't believe 'em! Way to go Bigdeezil58.
Old Jan 21, 2002 | 02:52 PM
powerstroker250's Avatar
powerstroker250
Never have plugged in my truck, starts every morning. Never have plugged in the 2 at work in almost 7 years, they start everytime.
Les
Old Jan 21, 2002 | 02:58 PM
powerstroker250
Old Jan 22, 2002 | 12:03 AM
BigDeezil58
Monsta, as we grow older we should realize that........
IT'SALLGOOD! (In terms of Ford trucks anyway)
helloimjason
Mar 15, 2017 08:49 PM
dscabra
Jan 29, 2014 11:53 AM
eltonmcrae
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Jan 2, 2011 12:32 PM
Dvandy21
Dec 16, 2010 07:31 PM
mahd776
Jan 6, 2010 07:00 AM
