hard starting
Old Sep 20, 2009 | 10:17 PM
poor15's Avatar
poor15
hard starting
1997 f350 7.3 5spd tranny 200k i have to slam the clutch to floor to start and sometimes she wont start untill i do it a few times with each time geting harder and harder to start any tip tricks ideas would be appericated thank you
Old Sep 20, 2009 | 10:57 PM
bryanlindborg600's Avatar
bryanlindborg600
could be your swtich down on the clutch pedal going bad??
Old Sep 20, 2009 | 11:21 PM
RubberDuck's Avatar
RubberDuck
Yep, there's a switch on the clutch pedal that won't let the truck start till the pedal is pushed. Sounds like it's going bad.
Old Sep 20, 2009 | 11:29 PM
MustangMatt96GT's Avatar
MustangMatt96GT
IMO it sounds like the worn out clutch bushing.... not the actual switch...
here is a link to fix it.
http://jbrlsr.com/?aid=5336108633&bi...Q5fAccessories
Old Sep 21, 2009 | 04:22 AM
poor15's Avatar
poor15
what is the name of the switch iam going to call ford dealer 2day to get a price on the switch or if anyone has part number that would be great thank you
Old Sep 21, 2009 | 08:59 AM
MustangMatt96GT
its called a nuetral safety switch/ or a clutch pedal starting switch.
Old Sep 21, 2009 | 06:45 PM
ke5chn's Avatar
ke5chn
I just wired around it on mine then the cruise wont work. so i put the wire on a switch up under the dash makes a good kill switch.
Bill
Old Sep 21, 2009 | 09:29 PM
poor15's Avatar
poor15
ke5chn could you give me a lil more detail on what to wire and where to start
Old Sep 21, 2009 | 11:50 PM
pjwoolw's Avatar
pjwoolw
I used to just pull the plug on those and put a fuse in it. Fit perfect. Don't know if it would work on these though.
Old Sep 25, 2009 | 05:21 PM
poor15's Avatar
poor15
where is the switch that iam looking for to pull to add a fuse to it in order to bypass that switch
Old Sep 26, 2009 | 08:48 AM
bryanlindborg600
it plugs into the master cylinder down under the dash.. in line with the clutch pedal
Old Sep 30, 2009 | 09:01 AM
poor15's Avatar
poor15
got it fixed the problem thanks alot for the help i just pulled the connector from the switch on the clutch pedal and put 2 small fuses in place of the switch now my truck will start without the clutch enguaged perfect now my clutch falls off where there is a plastic bushing and gos stright to thr floor sometimes when iam driving i replaced the bushing already from ford that lil plastic piece is 10 $ and it is still falling off the shaft going straight to the floor any tips or trciks on this one????
Old Sep 30, 2009 | 12:49 PM
poor15's Avatar
poor15
Anyone please
Old Sep 30, 2009 | 01:13 PM
884x4broncoII's Avatar
884x4broncoII
get the e-bay clutch bushing fix, best money i have ever spent on my truck
Old Sep 30, 2009 | 08:58 PM
poor15's Avatar
poor15
which seller is trust worthy on ebay i have never delt with ebay before any particular way to pay without useing paypal can i pay with my credit card
