well last night came home rolled the passenger side up worked fine came out this morning and the window didnt work, i tried both switches and neither did anything soo i hit the switch panel on the passenger side door and its started working and worked fine all day...i had this exact problem one time before..any idea's?
One of the switches is probably dodgy... You're going to have to mess with it until you either figure out which one is the issue or it fails completely.
what you mean like either the window switch on my driver side or passenger side is going bad?? which one you have to guess since when its not working both switches are dead
i'll reset that plug but idk how that would help, but the problem gets fixed when i tap the passenger side switch panel or even just shuttin the door sometimes work..
I am just going by what had happened to me, I to started on the passenger side, but eneded up on the drivers side, so, I flipped a quarter and directed you by those results.
lol alright it unplugged and re plugged both switches just to be safe soo i guess we'll wait and see, its only does it ever soo often and if i open the passenger side door and then close it it will start working again..soo guess i'l wait and see
ok now we have the same problem again..soo does it defintly sound like a switch problem to you?? and for example if the passenger side switch is bad wouldnt the driver side still work?? or vice versa??
