Mirror Replacement
Old Sep 20, 2009 | 06:44 PM
wbymag's Avatar
wbymag
Mirror Replacement
My drivers side mirror was damaged (power) and needs to be replaced. I have the factory replacement but I am unsure how to pull the inside panel off (I can break things without too much effort....fixing them is another story). I would be extremely grateful if someone could provide the steps to pull off the necessary pieces of the door so I can get the replacement mirror installed.
My sincerest thanks in advance
Old Sep 20, 2009 | 08:38 PM
Still Smoking's Avatar
Still Smoking
Well you got two screws on the bottom of the door. I think they are 5.5mm. Then you take a screw driver and pry out the speaker piece. There are 4 bolts behind that. Dont remember size. Then take a small screw driver and pry the piece behind the door handle on the inside. There is one or two bolts there. Im pretty sure that is all of them. From there you just lift up on the door panel. It should come right off and you should be all set.
Old Sep 21, 2009 | 06:10 AM
dixiemudder04's Avatar
dixiemudder04
The speaker bolts are 5/32 i believe. u have a phillips screw close to the door handle. And u have to push in then up.
fredo181
Escape & Escape Hybrid
Nov 1, 2012 09:21 AM
Chrome Dome
Oct 28, 2009 08:15 PM
cclaunch
Nov 12, 2006 05:57 PM
mooncruiser
Aug 27, 2005 01:57 AM
UBDog
2004 - 2008 F150
Aug 23, 2005 11:19 AM
