4x4 Issues
Old Sep 20, 2009 | 11:46 AM
michael102105's Avatar
michael102105
4x4 Issues
Fourwheel drive wont ingage. replaced transfer case motor, switch on the dash, and relayes under the hood. Don't know where else to check or what else to replace if anyone has any tips or suggestions please let me know! Thanks
Old Sep 20, 2009 | 12:39 PM
EXv10's Avatar
EXv10
I would start by cleaning/greasing the esof hubs then do a search in here.
Old Sep 20, 2009 | 09:50 PM
michael102105
I have check every page on here thats deals with 4x4 an none of them are haveing my problems it doesnt have anything to do with the hubs it is the transfer case that wont engage the hubs i can engage manualy i have checked fuses, relays you name it. i am at wits end anybody have any ideas?
Old Sep 20, 2009 | 10:48 PM
wallz's Avatar
wallz
So you have 4x4 when you engage the hubs manually, and not when you try to go auto?
If that is the case search under the ESOF hubs. That is the auto locking 4x4 that uses a vacuum pulse to lock and unlock 4x4. I did also read in the superduty forum in the last few days someone having an issue with the 4x4 and it ended up being a relay that was bad. He said that even a ford parts guy could not come up with an answer that there was a relay.
Old Sep 20, 2009 | 11:27 PM
EXv10's Avatar
EXv10
The search in here is a little tricky but try again and believe me; everything that pretains to you problem is in here.
Old Sep 21, 2009 | 05:31 AM
katiesdad7's Avatar
katiesdad7
I have read many forums about this issue and they all seem to point to the front hubs.
Old Sep 21, 2009 | 03:01 PM
hvacguy's Avatar
hvacguy
Agreed with all the others. Check the front hub operation.
Old Sep 21, 2009 | 04:43 PM
Stewart_H's Avatar
Stewart_H
Your hubs are vacuum actuated. The ESOF going out is a very common problem. You probably just need this:
http://www.dieselsite.com/index.asp?...ROD&ProdID=348
Stewart
Old Sep 21, 2009 | 05:38 PM
cbradford's Avatar
cbradford
Stewart
Thanks just what I was looking for.
Old Sep 21, 2009 | 05:39 PM
Stewart_H's Avatar
Stewart_H
Welcome!
Stewart
Old Sep 21, 2009 | 08:16 PM
muddman77's Avatar
muddman77
Even if his hubs werent working the t case should still engage, it just wouldnt turn the front wheels. This doesnt sound like a vacuum leak. Vacuum has nothing to do with the tc engageing, just hubs.
Old Sep 21, 2009 | 08:18 PM
michael102105
the tranfer case is my problem it wont engage no lights on dash no power to the motor on the transfer case i have replaced relays checked fuses replaced switch an the motor on the transfer case.
Old Sep 21, 2009 | 08:46 PM
EXv10's Avatar
EXv10
It sounds like your 4x4 module . Open it up and see if there is amy corrosion in it.
Old Sep 21, 2009 | 09:10 PM
michael102105
where is the 4x4 module located at?
Old Sep 21, 2009 | 10:50 PM
EXv10's Avatar
EXv10
i think it is under the dash on the extreme right side but maube someone else will chime in. Not sure if it is the GEM module...expensive.
