Core Plug - Bad Repair
Old Sep 20, 2009 | 05:21 AM
RickyFutura's Avatar
RickyFutura
Hi All,
Have discovered a previous owners 'fix' while I had the truck on a friends ramp - looks like a core plug leaked at some point and rather than replace it properly the individual put a big messy weld around/over it - looks like there's a weld to the right of the plug too - but I'm unsure if this hiding/fixing an additional problem or just more bad/messy welding.
Question is... the plug in question is on the rear right hand side (if sitting in the truck) of the block (above the starter) are there any known issues with (a) this core plug and (b) this area of the block in general.
Looks also like the weld is weeping coolant a little too - not lots - but some (which is too much) only fix I can see bar replacing the block is to grind back and do a better weld job - any other thoughts would be welcome.
Cheers
Richard
Old Sep 20, 2009 | 07:00 AM
mistakenID's Avatar
mistakenID
The early 6.9 block did have a weak area around the block heater area. That is the same area you are describing.
Some blocks developed a crack in that area. Generally associated with using the block heater often. If I remember the dates right, up to early 85 could have the problem.
Old Sep 20, 2009 | 10:03 AM
Brimmstone's Avatar
Brimmstone
I've used these for years. They work great.
http://www.locknstitch.com/
Old Sep 20, 2009 | 01:11 PM
joe f350's Avatar
joe f350
is it gb weil
Old Sep 20, 2009 | 01:53 PM
Brimmstone's Avatar
Brimmstone
Why not look at the link and do a little research. I'm sure the more knowledgeable members of the site at least are doing that before asking a question.
Old Sep 20, 2009 | 09:59 PM
Dave Sponaugle's Avatar
Dave Sponaugle
What year is the engine?
I see 84 in your specs.
The hole right over the starter is where the block heater should be.
I have to wonder is the heater started leaking and someone tried to install the wrong size freeze plug, which also leaked, so they tried to weld it in.
84 blocks were a little thinner at the block heater area, and have been known to crack there if the block heater is used a lot.
Nice looking truck if your avitar is your truck.
Old Sep 21, 2009 | 12:55 AM
Dodge/Cummins's Avatar
Dodge/Cummins
That'd be a first.
Surely you jest!
Old Sep 21, 2009 | 04:49 AM
RickyFutura
Thanks for the directives... Both the LNS link and advice to 'search' harder in future. In my defence... Maybe the US term is Freeze Plug - so my Core Plug search was set to fail? Our two countries seperated by a common language spreads far and wide into automotive terminology... More to come.
Thanks Dave (yet again) - for what's likely to root of it, the trucks an 84 (built Sept '83) - Have read about the Block Heater issues in your previous threads - so good to have possible cause and effect to mull over.
Truck is indeed mine - thanks for the words - slowly getting her straight.
Best - Richard
Old Sep 21, 2009 | 06:56 AM
Brimmstone's Avatar
Brimmstone
Actually that was directed to the poorly spelled JB weld question
Old Sep 21, 2009 | 09:45 AM
RickyFutura
Stand corrected. R
Old Sep 21, 2009 | 09:57 AM
Brimmstone's Avatar
Brimmstone
I can say I have used the LNS products to repair a fair number cummins engines since I was introduced to them. I have also used them to fix the core plug leak you are dealing with. I cut a piece of steel the size of the plug and then anchored it with the LNS screws like they show on the site. Last I heard it is still running and is still dry
Old Sep 21, 2009 | 10:12 AM
RickyFutura
That's good to know - the LNS procedure looks like good solution if I decided to do it myself... found these guys in the UK if I choose easy (read: expensive) street...
http://www.castironweldingrepairs.co...ng-repairs.php
Old Sep 21, 2009 | 10:16 AM
Brimmstone's Avatar
Brimmstone
It can be done but you need to be extremely good to do it.
Old Sep 21, 2009 | 10:06 PM
Dodge/Cummins
Same here.
Old Sep 21, 2009 | 10:24 PM
Brimmstone's Avatar
Brimmstone
I'm going through my files tonight. I know there is another repair method for cast iron cracks I just have to find where I saved the info
