Staun Internal Bead Locks
Old Sep 18, 2009 | 01:18 AM
rikosintie's Avatar
rikosintie
I got caught up in the defective Chinese valve stem recall. I bought the tires and wheels at Four Wheel Parts so I called them and they said they would replace them for free.
I had been wanting to install a set of Staun Internal Bead Locks for a long time so I asked if they would break the wheels down and let me take the rims home to drill the holes for the bead lock.
They said no problem so I bought two bead locks for the front, they are almost $200 each and I didn't want to spend $800 unbudgeted dollars right now, and brought the wheels home. I watched the Staun video several times and finally got up the nerve to drill the hole in the rim. I measured a couple times and then put the wheel back on the spindle to check clearance with the caliper.
Four Wheel Parts in Riverside, CA remounted the tires with the bead locks inside. I plan to take it out this weekend and air down to around 8 PSI to test them out.
Here is a picture of the bead lock stem on the inside of the wheel.
http://s268.photobucket.com/albums/j...rent=Staun.jpg
Here is a link to the Staun Internal Bead Lock page
http://www.staunproducts.com/beadlock.php
Michael
Last edited by rikosintie; Sep 18, 2009 at 01:22 AM. Reason: Picture link not working
f100today
17
Oct 22, 2011 09:44 PM
erichy
Sep 19, 2011 07:56 PM
dvldog458
Oct 3, 2010 06:51 AM
seminaryranger
Aug 26, 2009 11:55 AM
dmpruss
1978 - 1996 Big Bronco
May 12, 2009 12:21 PM
