Air Conditioning
Old Sep 17, 2009 | 06:02 PM
irondragon1's Avatar
irondragon1
Air Conditioning
I have a 1995 f 150 with a bit of an a/c problem. The air is cold but when I start moving it seems like it is diverted somewhere else. I can hear the fan still blowing but the air stops coming out for a short time. I can hear something behind the radio that sounds like maybe it is opening and closing. I am guessing there is some kind of a box for lack of a better word that controls where the air should go that is not working. Any info would be helpfull. I am and ex Chevy owner and am new to Ford.
Michael
Old Sep 17, 2009 | 06:14 PM
Dodge-My-Cummins's Avatar
Dodge-My-Cummins
The "trap" doors are vacuum operated, each door has a little solenoid/diaghram thing.
If one of them goes bad... the door does funky stuff or doesn't do what its supposed to.
Its not going to the floor is it?? My 91 GMC pickup has the same problem sometimes
Old Sep 17, 2009 | 06:22 PM
jr32560's Avatar
jr32560
agreed or a line going to one of em has a crack my 95 E250 doing the same thing
just ain't had time to figure which it is yet
Old Sep 17, 2009 | 06:25 PM
TexasGuy001's Avatar
TexasGuy001
Whats most likely happening is that the air is coming out the defrost vents. There is probably a vacuum leak. Check the T shaped check valve between the engine and the heater box under the hood. That can fail and cause problems.
Mine has done this a couple times. That valve was the problem the first time or two. The last time was the white vacuum line on the vacuum motor on top of the heater box under the hood. Its in the very corner of the engine bay. Anyway, that line was cracked and deteriorated. I couldn't find that one and had the local shop I use find the vacuum leak. They use a smoke machine and look for where the smoke is comming out.
Old Sep 17, 2009 | 06:27 PM
subford's Avatar
subford
Check for a broke white vacuum line under the hood in this photo:
Old Sep 20, 2009 | 08:23 AM
irondragon1
How do you test the valve?
Old Sep 20, 2009 | 10:45 AM
subford's Avatar
subford
Deleted Deleted
Old Sep 21, 2009 | 01:09 AM
TexasGuy001
The white line that subford showed is the same one I was talking about.
Its just a little 3 dollar check valve. I just replaced it.
Old Sep 21, 2009 | 12:20 PM
skaterbro's Avatar
skaterbro
Here's where the white vacuum line goes to under the dash:
You can see the little junction with the foam wrapped around it. The white line coming in from the bottom of it is the vacuum line shown in Subford's pic. I pulled it out a little so it'd be visible. But it's right behind the passenger kick panel.
Old Sep 22, 2009 | 10:03 PM
rla2005's Avatar
rla2005
Use a hand-held vacuum pump. Apply vacuum to the circuit, see if it holds vacuum. Move the airflow **** on the dash, see if the diverter valve moves. The white hose leading to the valve is a well known cause of this problem as well as cracked vacuum lines leading from the manifold and the little vacuum reservoir attached to the side of the blower/evaporator box. I used my vacuum tester for all the vacuum circuits on my '92 F350. After finding multiple failures I replaced all the vacuum lines. Now my idle is steady at 600RPM and my airflow does not change at every throttle position change.
Old Sep 23, 2009 | 01:59 PM
Dodge-My-Cummins
Did you get my comment on ur profile.... use your mouth. LIke when you test a vacuum modulator on an old distributor.
Big-Red-Lariat
2015 - 2020 F150
Apr 16, 2016 10:14 PM
BigBodySage
Jun 14, 2013 10:26 PM
Bukiman
Oct 19, 2011 04:40 AM
rockos3354
Escape & Escape Hybrid
Sep 19, 2010 11:47 PM
Jeepian
2004 - 2008 F150
Mar 24, 2010 07:09 PM
