Steering/Front Conversion
Old Sep 17, 2009 | 01:47 PM
The Freak's Avatar
The Freak
I just purchased a 78 F250 with a D60 front. I plan on removing the closed knuckle, drum brake D60 front from my 75 Crew Cab and putting the 78 front under it. I know bolting in the axle will be simple, but are there any tricks to know when converting the 75 to the 78 steering setup?? From what I gathered the 78 steering is alot better setup. I'm picking the 78 up tonight so I haven't had a chance to take a look at the two different steering setups, but I figured someone on here had done the swap before so they would know what details are entailed in getting the job done. Any info/tips are appreciated.
Thanks!!
Old Oct 26, 2009 | 02:05 PM
Skip1970's Avatar
Skip1970
Thanks!!
far as i know it should bolt righ tin, the axle that is, the steering i dont think so. do a search i know there are several threads describing how to swap... someday i will do that same swap.
Ray
Old Oct 26, 2009 | 02:25 PM
zak8tac's Avatar
zak8tac
Are you 100% certain that 78 has a d60 front?
bkwdscrzr
Feb 12, 2013 11:41 PM
79OldBone
45
Oct 27, 2011 04:20 PM
shiffty
Dec 14, 2009 10:14 PM
JimBoB77
Jul 22, 2008 03:16 PM
johnyrabbit
Feb 19, 2004 02:03 PM
