Sponsored by: Real Truck
shift on the fly problem
Old Sep 19, 2009 | 03:14 PM
EXv10's Avatar
EXv10
It's not hard to take the hubs apart and service them.
Old Sep 19, 2009 | 07:40 PM
fmly fun's Avatar
fmly fun
it,s a cich just did both in about an hour and have never done it before.but now the esof works but not in reverse anyone heard about this happening?it was pretty srtaight forward i can't see putting it together wrong.
Old Sep 19, 2009 | 07:50 PM
Bone683's Avatar
Bone683
well got the vacuum back, well i was there figured i would clean the hub up since i never have. took me about 20 minutes to get one off. once it was off the old bearing grease had just turned into dirt the just rolled around in there. pulled it apart and the bearing inside there was done fell apart in in my hands....
Old Sep 21, 2009 | 06:15 PM
fmly fun's Avatar
fmly fun
any ideas why esof won't work in reverse
Old Sep 21, 2009 | 09:34 PM
XLnAK's Avatar
XLnAK
Yikes Bone, thats probably what I'll find to. I'm thinking ill need an outer stub shaft, when I get into mine. Its the inner needle bearings that fell apart in your hands right? or are you talking about a bearing in the selector hub? I'm thinking of the complete rebuild kits (both wheel bearings and all seals.) that I have seen listed in threads hear. Has it solved your issue? Good to see another member from AK.
Old Sep 22, 2009 | 10:52 AM
Bone683's Avatar
Bone683
Yes it was the bearing in the hub it self. Broke down and got the warn manual hubs, solved my woes and looks better to. There is no room for second guessing when wheeling in AKs back country
Old Oct 10, 2009 | 07:19 PM
4u2ford's Avatar
4u2ford
mine wont shift either but i have no 4x4 light when i first turn on the ignition any ideas
Old Oct 10, 2009 | 07:46 PM
Bone683's Avatar
Bone683
Burned out light in the dash maybe. Can you hear the shift motor engaging if you turn it to 4x4
Old Oct 10, 2009 | 08:24 PM
EXv10's Avatar
EXv10
Maybe the expensive GEM module
Old Oct 10, 2009 | 11:07 PM
4u2ford's Avatar
4u2ford
no shift lights
no noise in motor or relays no think it might be my 4x4 module behind the glove box
Old Oct 23, 2009 | 03:27 AM
scott alvarez's Avatar
scott alvarez
It sound like to me your relays under your hood next two the master cylinder. That is what my truck did no lights came on transfercase shift motor would not work. It was the relays under your hood. one makes the trans shift from 2 to 4 to 4 low. the other takes it from 4 low to 4 high to 2 wheel. hope this helps
Trident
Jan 16, 2015 10:20 PM
fordbroncodave
1978 - 1996 Big Bronco
Dec 8, 2011 08:07 PM
bullpin
Oct 9, 2011 02:26 PM
cdrmotorsports
General Automotive Discussion
Oct 2, 2009 07:20 PM
coach04heat
Jan 28, 2008 05:41 PM
