Fuel pump problem
Old Sep 15, 2009 | 09:02 PM
1968mustang302's Avatar
1968mustang302
Fuel pump problem
as some of you may know my truck is having a problem. it will not start due to the fuel pump not turning on (no fuel pressure) it is a 1985 f150. the fuel pump is knew so is the PCM.. let me know what you guys think, i want to get this thing running this week<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old Sep 15, 2009 | 09:20 PM
393STROKER's Avatar
393STROKER
I`ve had the fuel relay switch go bad on my `90.It`s a 1 " square electrical plug that goes in the wiring harness on the drivers side wheel well,but I don`t know if yours is the same.
Old Sep 16, 2009 | 03:37 AM
JJ98's Avatar
JJ98
did you check the ground also you could check the plug for voltage if no volt check he relay in the fuse box good luck
Old Sep 16, 2009 | 07:24 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Sounds like the inertia switch to me. But I too have no idea where it is on your vehicle. Could be as simple as resetting it.
Old Sep 17, 2009 | 12:58 AM
1968mustang302
its grounded through the pcm.. i will check voltage at the plug when i have time, in between my 80 hour work week
