Rough Running
Old Sep 15, 2009 | 07:32 PM
TheWingnut's Avatar
TheWingnut
Rough Running
My 250 4.9L I6 runs rough until I get it above 55, especially between 3 and 4 gear, kind of hoppy and jerky can anyone suggest something to try to fix it?
Old Sep 16, 2009 | 10:45 PM
TheWingnut's Avatar
TheWingnut
So no one has any idea's? Am I missing some information?
Old Sep 17, 2009 | 09:46 AM
AbandonedBronco's Avatar
AbandonedBronco
Are you certain it's engine related? Generally, rough running has to do with RPM, not vehicle speed. If it's vehicle speed related, it could be bad motor mounts, tranny mounts, problems with the driveshaft, etc.
Old Sep 17, 2009 | 01:15 PM
Beechkid's Avatar
Beechkid
When was the last time it was given a complete tune-up? Typically low speed miss can also be caused by weak coil/ignition module, tired/mis-adjusted ignition points (don't know if the 83 had those), hairline crack in the distributor cap, worn ignition rotor, tired spark plugs/wires, EGR valve dirty or actuator tired....
gearhead5
Mar 26, 2016 07:16 PM
Danp65
Dec 3, 2015 09:32 AM
Jpare32
2004 - 2008 F150
May 12, 2015 06:56 AM
Milly1219
2004 - 2008 F150
Jun 11, 2014 09:48 PM
RCSB4x4
3.8 & 4.2L V6
Jun 25, 2008 08:17 PM
