Does anyone know how to program the RKE on a 94 ford e150 van. I have tried to cycle the ignition from off to run 5 and 8 times after reading previous post and nothing happens.
I found the black connector with the two wires stripped in yellow. I used a paper clip to just touch the two connectors while the ignition key was in the "run" position. It cycled to lock and back to unlock. . . . . Hurrah! while still holding the paper clip in place, I had my wife push the lock button on one remote, it cycled, and then the other and it too cycled.
I turned the ignition off and pulled the jumper wire.
